Problems showing display - Arduino Mega 2560 and Adafruit 1.8" TFT shield
Hello Everyone,
I am a bit rusty but trying to get this code working for my project. It was originally coded for a different display using the same Arduino board I currently have. I am fairly sure the code at lines 46 & 48 are giving me the issues. Code compiles fine, only issue is getting anything to display.
I have gotten test example using different libraries to work so I know hardware/soldering is good.
- seesaw_shield18_test.ino - adafruit libs examples
Problem code:
UTFT myGLCD(ITDB32S,38,39,40,41);
ITDB02_Touch myTouch(6,5,4,3,2);       ////////////////////////////////////////////////////////////////////
I know the model below is correct from the UTFT documentation but feel the numbering for the pins is incorrect and all combinations I have found do not work
UTFT myGLCD(ITDB18SP, , , ,);
Thank you ahead of time whoever may reach out to help.
Hardware:
Arduino Mega 2560
Adafruit 1.8" TFT shield, 3 button + joystick
Below is full code, warning there is some French and what not but should be irrelevent, code is otherwise working fine for anther screen.
//#include <UTFT_SdRaw.h>     /////////////////////////////////////////////////////////////////////////////////////////////////////////////////////
// ATTENTION, Le Touch screen ne fonctionne pas avec la librairie UTOUCH et URTOUCH, il faut ITDB02_Touch
//    V1.05
//Inversion de la logic capteur pour D-M9BV
//    V1.04
//Passage en Long pour les cycles
//    V0.03
//Ajout du capteur fin de course
//Ajout de la mérmoire EEPROM pour sauvegarder les derniers paramètres de cycles
#define VERSION "v1.05"
#include <UTFT.h>
//#include <URTouch.h>        /////////////////////////////////////////////////////////////////////////////////////////////////////////////////////
#include <EEPROM.h>
#include <ITDB02_Touch.h>     /////////////////////////////////////////////////////////////////////////////////////////////////////////////////////
#define PINDISTRIBUTEUR 13
#define PINCAPTEUR      12
extern uint8_t SmallFont[];
extern uint8_t BigFont[];
unsigned long LastTimer    = millis();
boolean CycleEnCours=0;
boolean Distributeur=0;    // 0 OFF – 1 ON
boolean Capteur     =1;    // 1 On continue, 0 Arret
unsigned long CycleFait =0 ;
unsigned long Cycles;     // récupuré dans la mémoire
unsigned int TempsHaut;   // récupuré dans la mémoire
unsigned int TempsBas;    // récupuré dans la mémoire
//ITDB02_Touch URTouch(6,5,4,3,2);     /////////////////////////////////////////////////////////////////////////////////////////////////////////////////////
ITDB02_Touch myTouch(6,5,4,3,2);       /////////////////////////////////////////////////////////////////////////////////////////////////////////////////////
int x, y;
byte pageidP;
byte pageid = 10;   //  Remettre 10
                    //  5   réservé page démarrage
                    //  10  menu
                    //  20  page paramètrage
                    //  30  Page DCY
                    //  40 Page de tarage
                    //  120 Ouverture clavier numérique
char stCurrentNum[10]="";
byte stCurrentNumLen=0;
byte donneeClavierNum;    // stock la position de la donnée en cours de modification
boolean maj = 0;
////////////////////////////////////////SETUP//////////////////////////////////////////
  SetUpEEPROM();  // a commenter apres le versement.
  Cycles    = EEPROMReadLong(0) ;
  TempsHaut = EEPROMReadInt(4) ;
  TempsBas  = EEPROMReadInt(6);
  pinMode(11, OUTPUT);
  digitalWrite(11, HIGH);
  pinMode(PINDISTRIBUTEUR, OUTPUT);
  digitalWrite(PINDISTRIBUTEUR, LOW);
  pinMode(PINCAPTEUR, INPUT_PULLUP); // Le capteur est à relier à la masse,The sensor must be grounded
  myGLCD.InitLCD(LANDSCAPE);
  myGLCD.clrScr();
  myTouch.InitTouch(LANDSCAPE);
  myTouch.setPrecision(PREC_LOW);
  myGLCD.setFont(BigFont);
  glcdAffichage();
/////////////////////////////////////////LOOP//////////////////////////////////////////
  if ( pageid == 30 || pageid == 40) testCapteurFinDeCourse();
  if ( CycleEnCours==1 && ( (Distributeur ==0 && (long)(millis()-LastTimer) > TempsBas) || (Distributeur ==1 && (long)(millis()-LastTimer) > TempsHaut)))
     fonctionDistributeur();
  if (myTouch.dataAvailable())
    Serial.println("ActionTouchPad();");
    actionTouchPad();
    delay(200);
//////////////////////////////////////FONCTIONS////////////////////////////////////////
void testCapteurFinDeCourse()
   Capteur = digitalRead (PINCAPTEUR);
   Capteur = !Capteur;
   myGLCD.printNumI(Capteur,CENTER,90+25);
   if ( CycleEnCours == 0)  return; // Si tout va bien, on ne fait rien, if all goes well, we do nothing
   if ( Capteur == 1)  return; // Si tout va bien, on ne fait rien, Si tout va bien, on ne fait rien
   CycleEnCours = 0;
   Distributeur = 0;
   digitalWrite(PINDISTRIBUTEUR, Distributeur) ;
   boutonString(5, 5, 310,29, "ESSAI INTERROMPU"  , 45,6, 255, 255, 255,1);   // En rouge
   boutonString(10, 200, 153,29, "PRECEDENT"  , 6,6, 255, 255, 255,1); // Bouton PRECEDENT
   myGLCD.printNumI(Distributeur,CENTER,40+25);
void fonctionDistributeur()
  Distributeur = ! Distributeur;
  if (Distributeur == 1)
    CycleFait++;
    myGLCD.printNumI(CycleFait,90,150);
    if (CycleFait==Cycles)
      CycleEnCours = 0;
      Distributeur = 0;
      boutonString(5, 5, 310,29, "ESSAI TERMINE"  , 45,6, 255, 0, 0,1);   // En rouge
///////////////////////////////////////EEPROM//////////////////////////////////////////
void SetUpEEPROM()
   EEPROMWriteLong(0, 123456789); //Cycle
   EEPROMWriteInt(4, 500);    //TempsHaut
   EEPROMWriteInt(6, 500);    //TempsBas
//This function will write a 2 byte integer to the eeprom at the specified address and address + 1
void EEPROMWriteInt(int p_address, int p_value)
  byte lowByte = ((p_value >> 0) & 0xFF);
  byte highByte = ((p_value >> 8) & 0xFF);
  EEPROM.write(p_address, lowByte);
  EEPROM.write(p_address + 1, highByte);
//This function will read a 2 byte integer from the eeprom at the specified address and address + 1
unsigned int EEPROMReadInt(int p_address)
  byte lowByte = EEPROM.read(p_address);
  byte highByte = EEPROM.read(p_address + 1);
  return ((lowByte << 0) & 0xFF) + ((highByte << 8) & 0xFF00);
//This function will read a 4 byte integer from the eeprom at the specified address and address + 3
void EEPROMWriteLong(int address, long value)
 byte four = (value & 0xFF);
 byte three = ((value >> 8) & 0xFF);
 byte two = ((value >> 16) & 0xFF);
 byte one = ((value >> 24) & 0xFF);
 EEPROM.write(address, four);
 EEPROM.write(address + 1, three);
 EEPROM.write(address + 2, two);
 EEPROM.write(address + 3, one);
//Read the 4 bytes from the eeprom memory.
long EEPROMReadLong(long address)
 long four = EEPROM.read(address);
 long three = EEPROM.read(address + 1);
 long two = EEPROM.read(address + 2);
 long one = EEPROM.read(address + 3);
 return ((four << 0) & 0xFF) + ((three << 8) & 0xFFFF) + ((two << 16) & 0xFFFFFF) + ((one << 24) & 0xFFFFFFFF);
//////////////////////////////////////AFFICHAGE////////////////////////////////////////
void glcdAffichage() //redessine la page complète, efface les données
//Page 10. Page Menu
  if(pageid==10)
    myGLCD.fillScr(100, 200, 230);   // bleuté
    myGLCD.setColor(0,0, 0); // noir
    myGLCD.setBackColor(100, 200, 230);   // sur bleuté
    myGLCD.print("Menu",CENTER,12);
    boutonString(50, 50, 200,29, "Tarage Verin"  , 6,6, 255, 255, 255,1); // Bouton Tarage Vérin
    boutonString(50, 100, 200,29, "Test Cycles"  , 6,6, 255, 255, 255,1); // Bouton Tarage Vérin
    myGLCD.print(VERSION, 225, 215);
//Page 20. Paramétrage du cycle
  if(pageid==20)
    myGLCD.print("Parametrage Cycle",CENTER,12);
    myGLCD.printNumI(Cycles,170,50);
    myGLCD.printNumI(TempsHaut,200,75);
    myGLCD.printNumI(TempsBas,200,100);
    myGLCD.print("ms",270,75);
    myGLCD.print("ms",270,100);
    myGLCD.print("ms",270,135);
    myGLCD.print("Duree cycle:",5,135);
    myGLCD.print("Duree essai:",5,160);
    myGLCD.printNumI(TempsBas+TempsHaut,200,135);
    boutonString(8, 48, 150,20, "Nb Cycles"   , 10,4, 255, 255, 255,0); // Bouton CYCLES
    boutonString(8, 73, 150,20, "Duree Haute" , 10,4, 255, 255, 255,0); // Bouton TEMPS HAUT
    boutonString(8, 98, 150,20, "Duree Basse" , 10,4, 255, 255, 255,0); // Bouton TEMPS BAS
    boutonString(180, 200, 122,29, "SUIVANT"  , 6,6, 255, 255, 255,1);  // Bouton SUIVANT
    unsigned long reste = Cycles*((TempsBas+TempsHaut)/1000.0);
    if ( reste < 3600 )
      int Minutes = reste/60;
      if (Minutes >=60) Minutes =59;
      myGLCD.printNumI(Minutes,200,160);
      myGLCD.print("M",240,160);
    else if ( reste >=3600 && reste < 86400)
      int Heure = reste/3600;
      myGLCD.printNumI(Heure,200,160);
      myGLCD.print("H",235,160);
      int Jour = reste/86400;
      myGLCD.printNumI(Jour,200,160);
      myGLCD.print("J",290,160);
   delay(500); // pour eviter de rentre trop vite dans la saisie
//Page 30. DCY
  else if(pageid==30) // Page test
    boutonString(5, 5, 310,29, "Depart/Reprise"  , 30,6, 255, 255, 255,1); // Bouton Depart
    myGLCD.printNumI(0,90,150);
    myGLCD.print("/",90,150+25);
    myGLCD.printNumI(Cycles,110,150+25);
    myGLCD.print("Etat distributeur",CENTER,40);
    myGLCD.print("Etat Capteur",CENTER,90);
//Page 40. Page Tarage
  else if(pageid==40)
    boutonString(5, 5, 310,29, "OFF"  , 140,6, 255, 255, 255,1); // Bouton OFF
//120. Clavier numérique
  else if(pageid==120)
    boutonString(35, 25, 250,200, "" , 20,20, 255, 255, 255,0);
    boutonString(40, 30, 240,40, "" , 5,5, 100, 200, 230,0);
    myGLCD.setFont(SmallFont);
    exempleNum();
    for ( byte i = 0; i<5 ; i++)
      for ( byte y = 0; y <2 ; y++)   boutonString(40+i*50, 80+50*y,40,40, String(i+5*y),11,11, 100, 200, 230,1);
    boutonString(40, 180, 90,40, "" , 11,11, 100, 200, 230,1);
    boutonString(140, 180, 40,40, "C" , 11,11, 255, 127, 39,1);
    boutonString(190, 180, 40,40, "A", 11,11, 255, 0, 0,1);
    boutonString(240, 180, 40,40, "V", 11,11, 0, 255, 0,1);
//////////////////////////////////////TOUCH PAD////////////////////////////////////////
void actionTouchPad()    //Actions liées au TouchPad
  //while (myTouch.dataAvailable())
  myTouch.read();
  x=myTouch.getX();
  y=myTouch.getY();
  Serial.print("x : ");
  Serial.print(x);
  Serial.print("   y : ");
  Serial.println(y);
//Page 10. Menu
  if ( pageid == 10 && x>=50 && y>=50 && x<=250 && y<=79) // Bouton Tarage Vérin
   AttenteSurCadre(50, 50, 250, 79);
   pageid=40;
   glcdAffichage();
  if ( pageid == 10 && x>=50 && y>=100 && x<=250 && y<=129) // Bouton Test Cycles
   pageid=20;
   glcdAffichage();
  if ( pageid == 20 && x>=180 && y>=200 && x<=302 && y<=229) // Bouton SUIVANT
   AttenteSurCadre(180, 200, 302, 229);
   pageid=30;
   glcdAffichage();
  else if ( pageid == 20 && x>=10 && y>=200 && x<=163 && y<=229)//Bouton PRECEDENT
   AttenteSurCadre(10, 200, 163, 229);
   pageid=10;
   glcdAffichage();
  else if ( pageid == 20 && x>=8 && y>=48 && x<=158 && y<=68) // Bouton CYCLES
   AttenteSurCadre(8, 48, 158, 68);
   donneeClavierNum=0;
   pageidP=pageid;
   pageid=120;
   glcdAffichage();
  else if ( pageid == 20 && x>=8 && y>=73 && x<=158 && y<=93) // TEMPS HAUT
   AttenteSurCadre(8, 73, 158, 93);
   donneeClavierNum=1;
   pageidP=pageid;
   pageid=120;
   glcdAffichage();
  else if ( pageid == 20 && x>=8 && y>=98 && x<=158 && y<=118) // TEMPS BAS
   AttenteSurCadre(8, 98, 158, 118);
   donneeClavierNum=2;
   pageidP=pageid;
   pageid=120;
   glcdAffichage();
//Page 30. DCY
  else if ( pageid == 30 && CycleEnCours==0 && x>=10 && y>=200 && x<=163 && y<=229)//Bouton PRECEDENT
   pageid=20;
   CycleFait=0;
   Distributeur=0;
   glcdAffichage();
  else if ( pageid == 30 && CycleEnCours==0 && Cycles!=CycleFait    && x>=5 && y>=5 && x<=315 && y<=34)// Bouton START
   AttenteSurCadre(5, 5, 315, 34);
   boutonString(5, 5, 310,29, "Cycle en cours..."  , 30,6, 255, 255, 255,1);
   boutonString(10, 200, 153,29, "PRECEDENT"  , 6,6, 255, 0, 0,1);
   if (Cycles != CycleFait) CycleEnCours =1;
   delay(800);
  else if ( pageid == 30 && CycleEnCours==1 && x>=5 && y>=5 && x<=315 && y<=34)// Bouton STOP
   CycleEnCours =0;
//Page 40. Tarage Vérin
  else if ( pageid == 40 && x>=10 && y>=200 && x<=163 && y<=229)//Bouton PRECEDENT
   pageid=10;
   Distributeur=0;
   glcdAffichage();
  else if ( pageid == 40 && x>=5 && y>=5 && x<=315 && y<=34)//Bouton ON/OFF
   Distributeur=!Distributeur;
  if (Distributeur==0)    boutonString(5, 5, 310,29, "OFF"  , 140,6, 255, 255, 255,1); // Bouton OFF
  else                    boutonString(5, 5, 310,29, "ON"  , 140,6, 255, 255, 255,1); // Bouton ON
  else if ( pageid==120 && x>=240 && y>=180 && x<=280 && y<=220)  // sortie avec sauvegarde
   AttenteSurCadre(240, 180, 280, 220);
   recupNombre();
   pageid=pageidP;
   glcdAffichage();
  else if ( pageid==120 && x>=190 && y>=180 && x<=230 && y<=220)  // sortie sans sauvegarde
   AttenteSurCadre(190, 180, 230, 220);
   initCurrentNum();
   pageid=pageidP;
   glcdAffichage();
  else if ( pageid==120 && x>=140 && y>=180 && x<=180 && y<=220)  // bouton correction
   AttenteSurCadre(140, 180, 180, 220);
   initCurrentNum();
   myGLCD.print("         ", 48, 195);
  else if ( pageid==120 && x>=40 && y>=80 && x<=80 && y<=120)  // bouton 0
   AttenteSurCadre(40, 80, 80, 120);
   updateStrNum('0');
  else if ( pageid==120 && x>=90 && y>=80 && x<=130 && y<=120)  // bouton 1
   AttenteSurCadre(90, 80, 130, 120);
   updateStrNum('1');
  else if ( pageid==120 && x>=140 && y>=80 && x<=180 && y<=120)  // bouton 2
   AttenteSurCadre(140, 80, 180, 120);
   updateStrNum('2');
  else if ( pageid==120 && x>=190 && y>=80 && x<=230 && y<=120)  // bouton 3
   AttenteSurCadre(190, 80, 230, 120);
   updateStrNum('3');
  else if ( pageid==120 && x>=240 && y>=80 && x<=280 && y<=120)  // bouton 4
   AttenteSurCadre(240, 80, 280, 120);
   updateStrNum('4');
  else if ( pageid==120 && x>=40 && y>=130 && x<=80 && y<=170)  // bouton 5
   AttenteSurCadre(40, 130, 80, 170);
   updateStrNum('5');
  else if ( pageid==120 && x>=90 && y>=130 && x<=130 && y<=170)  // bouton 6
   AttenteSurCadre(90, 130, 130, 170);
   updateStrNum('6');
  else if ( pageid==120 && x>=140 && y>=130 && x<=180 && y<=170)  // bouton 7
   AttenteSurCadre(140, 130, 180, 170);
   updateStrNum('7');
  else if ( pageid==120 && x>=190 && y>=130 && x<=230 && y<=170)  // bouton 8
   AttenteSurCadre(190, 130, 230, 170);
   updateStrNum('8');
  else if ( pageid==120 && x>=240 && y>=130 && x<=280 && y<=170)  // bouton 9
   AttenteSurCadre(240, 130, 280, 170);
   updateStrNum('9');
 // else
   myTouch.read();
   delay(50);
//////////////////////////////////////GRAPHISME////////////////////////////////////////
// Dessine un cadre rouge tant qu'une touche n'est pas relachée, permet de vider le buffer du pad
//Draws a red frame as long as a key is not released, allows to empty the pad buffer999
void AttenteSurCadre(int x1, int y1, int x2, int y2)
  myGLCD.setColor(255, 0, 0);        //rouge
  myGLCD.drawRoundRect (x1, y1, x2, y2);
   myTouch.read();
  delay(10);
  myGLCD.setColor(0, 0, 0);          //noir
void boutonString(int x, int y, int Lo, int la, String c, int xx, int yy, byte R, byte G, byte B, boolean Gras)
    myGLCD.setColor(R, G, B);
    myGLCD.setBackColor(R, G, B);
    myGLCD.fillRoundRect  (x,y, x+Lo , y+la);
    if(Gras==0) myGLCD.setFont(SmallFont);
    myGLCD.print(c,x+xx,y+yy);
    myGLCD.drawRoundRect (x,y, x+Lo , y+la);
    myGLCD.setBackColor(100, 200, 230);  //bleuté
//AFFICHE ET STOCKE LA VALEUR EN COURS DE FRAPPE
void updateStrNum(int val)
  if (stCurrentNumLen<9)
    stCurrentNum[stCurrentNumLen]=val;
    stCurrentNumLen++;
    stCurrentNum[stCurrentNumLen]='\0';
    myGLCD.print(stCurrentNum, 48, 195);
void initCurrentNum()
  stCurrentNum[0]='\0';
  stCurrentNumLen=0;
//RECUPERE LA VALEUR DANS LE CLAVIER NUMERIQUE
void recupNombre()
  if (stCurrentNumLen==0) return; // Le buffer est vide
  unsigned long n = atol(stCurrentNum);
  initCurrentNum();
  switch (donneeClavierNum)
    case 0:  // NOMBRE DE CYCLE
    if ( n==0) n=1;
    if ( n>=1000000000) n=999999999;   // <1 milliard
    Cycles = n;
    EEPROMWriteLong(0, Cycles);
    Serial.println(Cycles);
    case 1:  // DUREE HAUTE
    if ( n==0) n=1;
    if ( n>=10000) n = 9999;
    TempsHaut= (int)n ;
    EEPROMWriteInt(4, TempsHaut);
    Serial.println(TempsHaut);
    case 2:    // DUREE BASSE
    if ( n==0) n=1;
    TempsBas = (int)n;
    EEPROMWriteInt(6, TempsBas);
    Serial.println(TempsBas);
void exempleNum()
   case 0:
     myGLCD.print("Nombre de cycles < milliard",CENTER,36);
   case 1:
     myGLCD.print("Duree Haute en ms(1-9999)",CENTER,36);
     myGLCD.print("Ex : pour 2,5s, taper 2500",CENTER,51);
   case 2:
     myGLCD.print("Duree Basse en ms(1-9999)",CENTER,36);
Please post a link to the actual Shield that you have bought.
Google finds this one https://www.adafruit.com/product/802
Since the display is 160x128 with no Touch it is not going to work very well with a program written for a 16-bit parallel 320x240 SSD1289 with XPT2046 Touch controller
from UTFT.h
#define ITDB32S			2	// SSD1289  (16bit)
Buy a suitable 320x240 Shield that fits your Mega2560. Ask if you need help. Modern screens have probably got ILI9341 or ST7789 controllers.
Your small 160x128 Shield will be fine for "smaller" projects.
David.
