Problems trying strtok a string
I am attempting to read a string of data in the form of (YD###PI###) which will move two different servos in different directions. I think I know what I have to do, but I am getting erros. Here is my code
#include <Servo.h>
#include <string.h>
Servo myservo;  // create servo object to control a servo
                // twelve servo objects can be created on most boards
Servo ud;
Servo lr;
int pos = 0;    // variable to store the servo position
int udpos;
int lrpos;
String incoming;
char in[2];
char * pch;
  ud.attach(9);  // attaches the servo on pin 9 to the servo object
  lr.attach(10);
  if (Serial.available() > 0) {
                // read the incoming byte:
                //incoming = Serial.read();
                incoming=Serial.readString();
pch = strtok (incoming,"YDPI");
  while (pch != NULL)
    for(int i=0;i<2;i++)
      in[i]=pch;
    pch = strtok (NULL, "YDPI");
  lrpos=(0.44)*int(in[1])+70;
  lr.write(lrpos);
  udpos=(0.33)*int(in[0])+75;
  ud.write(udpos);
Here are my errors. Now sure how to fix?
I guess maybe I dont understand the difference between a string and a char array
servo.ino: In function 'void loop()':
servo:32: error: cannot convert 'String' to 'char*' for argument '1' to 'char* strtok(char*, const char*)'
servo:38: error: invalid conversion from 'char*' to 'char'
It's really not clear to me what you're trying to do, but I assume what you really want to extract is the two fields shows as #'s in (YD###PI###)? strtok will stop parsing as soon as it finds the first character match, so:
if incoming = "(YD123PI456)"
strtok(incoming, "YDPI") finds the delimiter "Y", and returns "("
strtok(NULL, "YDPI") finds the delimiter "D", and returns an empty string
strtok(NULL, "YDPI") finds the delimiter "P", and "123"
strtok(NULL, "YDPI") finds the delimiter "I", and returns an empty string
strtok(NULL, "YDPI") finds no delimiter, and returns "456)"
Regards,
Ray L.
You don't understand the difference between a String and zero terminated array of chars (aka a C style string)
Note the upper and lowercase s in String and string.
The parse example in serial input basics uses strtok() and may be a useful guide.
...R
Below is some test code for controlling several servos.
//zoomkat 11-22-12 simple delimited ',' string parse
//from serial port input (via serial monitor)
//and print result out serial port
//multi servos added
// Powering a servo from the arduino usually *DOES NOT WORK*.
String readString;
#include <Servo.h>
Servo myservoa, myservob, myservoc, myservod;  // create servo object to control a servo
  //myservoa.writeMicroseconds(1500); //set initial servo position if desired
  myservoa.attach(6);  //the pin for the servoa control
  myservob.attach(7);  //the pin for the servob control
  myservoc.attach(8);  //the pin for the servoc control
  myservod.attach(9);  //the pin for the servod control
  Serial.println("multi-servo-delimit-test-dual-input-11-22-12"); // so I can keep track of what is loaded
  //expect single strings like 700a, or 1500c, or 2000d,
  //or like 30c, or 90a, or 180d,
  //or combined like 30c,180b,70a,120d,
  if (Serial.available())  {
    char c = Serial.read();  //gets one byte from serial buffer
    if (c == ',') {
      if (readString.length() >1) {
        Serial.println(readString); //prints string to serial port out
        int n = readString.toInt();  //convert readString into a number
        // auto select appropriate value, copied from someone elses code.
        if(n >= 500)
          Serial.print("writing Microseconds: ");
          Serial.println(n);
          if(readString.indexOf('a') >0) myservoa.writeMicroseconds(n);
          if(readString.indexOf('b') >0) myservob.writeMicroseconds(n);
          if(readString.indexOf('c') >0) myservoc.writeMicroseconds(n);
          if(readString.indexOf('d') >0) myservod.writeMicroseconds(n);
          Serial.print("writing Angle: ");
          Serial.println(n);
          if(readString.indexOf('a') >0) myservoa.write(n);
          if(readString.indexOf('b') >0) myservob.write(n);
          if(readString.indexOf('c') >0) myservoc.write(n);
          if(readString.indexOf('d') >0) myservod.write(n);
         readString=""; //clears variable for new input
    else {
      readString += c; //makes the string readString
