Problems trying to upload code using LiquidCrystal_i2c.h library?
Im trying to use an Arduino Nano (reciever) to communicate with a Wemos d1 mini (transmitter) using Lora SX-1278 mudules with a 1602 LCD with i2c on the Nano.. having trouble with the code since im not very good and new to programming... I managed to get the two boards communicating with eachother using the Lora modules but when trying to add a LCD screen to the Nano (reciever) im having trouble using the LiquidCrystal_i2c library since nearly all the examples on Google are using this library.
Any help will be greatly appreciated....
Thanks.
Here is the copy of the error msg
Using board 'nano' from platform in folder: /Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6
Using core 'arduino' from platform in folder: /Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6
Detecting libraries used...
/Users/Adama/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/variants/eightanaloginputs /private/var/folders/1w/6h9htr_90tjf5xs7bqp8s3j80000gn/T/arduino-sketch-E7A4B3F0192FE9E5C39D1FE4B8755DAF/sketch/LoRaReceiver.ino.cpp -o /dev/null
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
/Users/Adama/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/variants/eightanaloginputs -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/SPI/src /private/var/folders/1w/6h9htr_90tjf5xs7bqp8s3j80000gn/T/arduino-sketch-E7A4B3F0192FE9E5C39D1FE4B8755DAF/sketch/LoRaReceiver.ino.cpp -o /dev/null
Alternatives for LoRa.h: [LoRa@0.8.0]
ResolveLibrary(LoRa.h)
-> candidates: [LoRa@0.8.0]
/Users/Adama/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/variants/eightanaloginputs -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/SPI/src -I/Users/Adama/Documents/Arduino/libraries/LoRa/src /private/var/folders/1w/6h9htr_90tjf5xs7bqp8s3j80000gn/T/arduino-sketch-E7A4B3F0192FE9E5C39D1FE4B8755DAF/sketch/LoRaReceiver.ino.cpp -o /dev/null
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
-> candidates: [Wire@1.0]
/Users/Adama/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/variants/eightanaloginputs -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/SPI/src -I/Users/Adama/Documents/Arduino/libraries/LoRa/src -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/Wire/src /private/var/folders/1w/6h9htr_90tjf5xs7bqp8s3j80000gn/T/arduino-sketch-E7A4B3F0192FE9E5C39D1FE4B8755DAF/sketch/LoRaReceiver.ino.cpp -o /dev/null
Alternatives for LiquidCrystal_I2C.h: [LiquidCrystal I2C@1.1.2]
ResolveLibrary(LiquidCrystal_I2C.h)
-> candidates: [LiquidCrystal I2C@1.1.2]
/Users/Adama/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/variants/eightanaloginputs -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/SPI/src -I/Users/Adama/Documents/Arduino/libraries/LoRa/src -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/Wire/src -I/Users/Adama/Documents/Arduino/libraries/LiquidCrystal_I2C /private/var/folders/1w/6h9htr_90tjf5xs7bqp8s3j80000gn/T/arduino-sketch-E7A4B3F0192FE9E5C39D1FE4B8755DAF/sketch/LoRaReceiver.ino.cpp -o /dev/null
Using cached library dependencies for file: /Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/SPI/src/SPI.cpp
Using cached library dependencies for file: /Users/Adama/Documents/Arduino/libraries/LoRa/src/LoRa.cpp
/Users/Adama/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/variants/eightanaloginputs -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/SPI/src -I/Users/Adama/Documents/Arduino/libraries/LoRa/src -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/Wire/src -I/Users/Adama/Documents/Arduino/libraries/LiquidCrystal_I2C /Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/Wire/src/Wire.cpp -o /dev/null
/Users/Adama/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/variants/eightanaloginputs -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/SPI/src -I/Users/Adama/Documents/Arduino/libraries/LoRa/src -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/Wire/src -I/Users/Adama/Documents/Arduino/libraries/LiquidCrystal_I2C /Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/Wire/src/utility/twi.c -o /dev/null
/Users/Adama/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/variants/eightanaloginputs -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/SPI/src -I/Users/Adama/Documents/Arduino/libraries/LoRa/src -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/Wire/src -I/Users/Adama/Documents/Arduino/libraries/LiquidCrystal_I2C /Users/Adama/Documents/Arduino/libraries/LiquidCrystal_I2C/LiquidCrystal_I2C.cpp -o /dev/null
Generating function prototypes...
/Users/Adama/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/variants/eightanaloginputs -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/SPI/src -I/Users/Adama/Documents/Arduino/libraries/LoRa/src -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/Wire/src -I/Users/Adama/Documents/Arduino/libraries/LiquidCrystal_I2C /private/var/folders/1w/6h9htr_90tjf5xs7bqp8s3j80000gn/T/arduino-sketch-E7A4B3F0192FE9E5C39D1FE4B8755DAF/sketch/LoRaReceiver.ino.cpp -o /private/var/folders/1w/6h9htr_90tjf5xs7bqp8s3j80000gn/T/arduino-sketch-E7A4B3F0192FE9E5C39D1FE4B8755DAF/preproc/ctags_target_for_gcc_minus_e.cpp
/Users/Adama/Library/Arduino15/packages/builtin/tools/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /private/var/folders/1w/6h9htr_90tjf5xs7bqp8s3j80000gn/T/arduino-sketch-E7A4B3F0192FE9E5C39D1FE4B8755DAF/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/Users/Adama/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/variants/eightanaloginputs -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/SPI/src -I/Users/Adama/Documents/Arduino/libraries/LoRa/src -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/Wire/src -I/Users/Adama/Documents/Arduino/libraries/LiquidCrystal_I2C /private/var/folders/1w/6h9htr_90tjf5xs7bqp8s3j80000gn/T/arduino-sketch-E7A4B3F0192FE9E5C39D1FE4B8755DAF/sketch/LoRaReceiver.ino.cpp -o /private/var/folders/1w/6h9htr_90tjf5xs7bqp8s3j80000gn/T/arduino-sketch-E7A4B3F0192FE9E5C39D1FE4B8755DAF/sketch/LoRaReceiver.ino.cpp.o
/private/var/folders/1w/6h9htr_90tjf5xs7bqp8s3j80000gn/T/.arduinoIDE-unsaved2022112-60477-1vylqxn.l98i/LoRaReceiver/LoRaReceiver.ino: In function 'void loop()':
/private/var/folders/1w/6h9htr_90tjf5xs7bqp8s3j80000gn/T/.arduinoIDE-unsaved2022112-60477-1vylqxn.l98i/LoRaReceiver/LoRaReceiver.ino:41:15: error: 'packet' was not declared in this scope
/private/var/folders/1w/6h9htr_90tjf5xs7bqp8s3j80000gn/T/.arduinoIDE-unsaved2022112-60477-1vylqxn.l98i/LoRaReceiver/LoRaReceiver.ino:41:15: note: suggested alternative: 'packetSize'
Using library SPI at version 1.0 in folder: /Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/SPI
Using library LoRa at version 0.8.0 in folder: /Users/Adama/Documents/Arduino/libraries/LoRa
Using library Wire at version 1.0 in folder: /Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/Wire
Using library LiquidCrystal I2C at version 1.1.2 in folder: /Users/Adama/Documents/Arduino/libraries/LiquidCrystal_I2C
exit status 1
Compilation error: 'packet' was not declared in this scope
And here is the copy of the sketch i have thumbled together using different examples
#include <SPI.h>
#include <LoRa.h>
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 16, 2);
  while (!Serial);
  lcd.init();
  lcd.backlight();
  lcd.setCursor(0,0);
  lcd.print("LoRa Receiver");
  delay(2500);
  lcd.clear();
  Serial.println("LoRa Receiver");
  if (!LoRa.begin(433E6)) {
    Serial.println("Starting LoRa failed!");
    lcd.setCursor(0,0);
    while (1);
You did not post your full sketch; loop() is missing.
This is a programming issue and hence your topic has been moved to a more suitable location on the forum.
Sorry about that i thought i got it all.
#include <Wire.h>
#include <SPI.h>
#include <LoRa.h>
  while (!Serial);
  lcd.begin();
  lcd.setCursor(0,0);
  delay(2500);
  lcd.clear();
  lcd.setCursor(0,0);
    while (1);
lcd.clear();
  int packetSize = LoRa.parsePacket();
  if (packetSize) {
    Serial.print("Received packet '");
    while (LoRa.available()) {
      Serial.print((char)LoRa.read());
    lcd.print(packet);
    Serial.print("' with RSSI ");
    Serial.println(LoRa.packetRssi());
    delay(2000);
Where LCD.begin(); starts i replaced it with
lcd.init();
lcd.backlight();
lcd.setCursor(0,0);
delay(2500);
lcd.clear();
and lcd.print(packet); gets highlighted.
hope that helps.
Please show the code that works. Which Lora library do you use?
I suspect that your editing took out some crucial stuff; there is indeed no variable called packet.
Im using the Sandeep Mistry Lora library.
Snapp...i basically took hours trying to find an example with the same setup and i only managed to find one that was close...
yeah im pretty much of a novice with Arduino programming.
Im using this sketch from Lora by Sandeep Mistry on the Nano and a different sketch on the D1 mini.
And i am trying to add my 1602 LCD with i2c to the Nano, on other forums they say that the liquid crystal_i2c library is at fault ? i dont know im following other sketches and apparently there working ?
#include <SPI.h>
#include <LoRa.h>
  while (!Serial);
    while (1);
  // try to parse packet
  if (packetSize) {
    // received a packet
    // read packet
    // print RSSI of packet
this is the original/first error after editing the working lora sketch..
Using board 'uno' from platform in folder: /Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6
/Users/Adama/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard /private/var/folders/1w/6h9htr_90tjf5xs7bqp8s3j80000gn/T/arduino-sketch-B849C62D738F51495C99F1AC58329D60/sketch/sketch_dec3a.ino.cpp -o /dev/null
/Users/Adama/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/Wire/src /private/var/folders/1w/6h9htr_90tjf5xs7bqp8s3j80000gn/T/arduino-sketch-B849C62D738F51495C99F1AC58329D60/sketch/sketch_dec3a.ino.cpp -o /dev/null
/Users/Adama/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/Wire/src -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/SPI/src /private/var/folders/1w/6h9htr_90tjf5xs7bqp8s3j80000gn/T/arduino-sketch-B849C62D738F51495C99F1AC58329D60/sketch/sketch_dec3a.ino.cpp -o /dev/null
/Users/Adama/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/Wire/src -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/SPI/src -I/Users/Adama/Documents/Arduino/libraries/LoRa/src /private/var/folders/1w/6h9htr_90tjf5xs7bqp8s3j80000gn/T/arduino-sketch-B849C62D738F51495C99F1AC58329D60/sketch/sketch_dec3a.ino.cpp -o /dev/null
/Users/Adama/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/Wire/src -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/SPI/src -I/Users/Adama/Documents/Arduino/libraries/LoRa/src -I/Users/Adama/Documents/Arduino/libraries/LiquidCrystal_I2C /private/var/folders/1w/6h9htr_90tjf5xs7bqp8s3j80000gn/T/arduino-sketch-B849C62D738F51495C99F1AC58329D60/sketch/sketch_dec3a.ino.cpp -o /dev/null
/Users/Adama/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/Wire/src -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/SPI/src -I/Users/Adama/Documents/Arduino/libraries/LoRa/src -I/Users/Adama/Documents/Arduino/libraries/LiquidCrystal_I2C /Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/Wire/src/Wire.cpp -o /dev/null
/Users/Adama/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/Wire/src -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/SPI/src -I/Users/Adama/Documents/Arduino/libraries/LoRa/src -I/Users/Adama/Documents/Arduino/libraries/LiquidCrystal_I2C /Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/Wire/src/utility/twi.c -o /dev/null
/Users/Adama/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/Wire/src -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/SPI/src -I/Users/Adama/Documents/Arduino/libraries/LoRa/src -I/Users/Adama/Documents/Arduino/libraries/LiquidCrystal_I2C /Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/SPI/src/SPI.cpp -o /dev/null
/Users/Adama/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/Wire/src -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/SPI/src -I/Users/Adama/Documents/Arduino/libraries/LoRa/src -I/Users/Adama/Documents/Arduino/libraries/LiquidCrystal_I2C /Users/Adama/Documents/Arduino/libraries/LoRa/src/LoRa.cpp -o /dev/null
/Users/Adama/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/Wire/src -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/SPI/src -I/Users/Adama/Documents/Arduino/libraries/LoRa/src -I/Users/Adama/Documents/Arduino/libraries/LiquidCrystal_I2C /Users/Adama/Documents/Arduino/libraries/LiquidCrystal_I2C/LiquidCrystal_I2C.cpp -o /dev/null
/Users/Adama/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/Wire/src -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/SPI/src -I/Users/Adama/Documents/Arduino/libraries/LoRa/src -I/Users/Adama/Documents/Arduino/libraries/LiquidCrystal_I2C /private/var/folders/1w/6h9htr_90tjf5xs7bqp8s3j80000gn/T/arduino-sketch-B849C62D738F51495C99F1AC58329D60/sketch/sketch_dec3a.ino.cpp -o /private/var/folders/1w/6h9htr_90tjf5xs7bqp8s3j80000gn/T/arduino-sketch-B849C62D738F51495C99F1AC58329D60/preproc/ctags_target_for_gcc_minus_e.cpp
/Users/Adama/Library/Arduino15/packages/builtin/tools/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /private/var/folders/1w/6h9htr_90tjf5xs7bqp8s3j80000gn/T/arduino-sketch-B849C62D738F51495C99F1AC58329D60/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/Users/Adama/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/Wire/src -I/Users/Adama/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries/SPI/src -I/Users/Adama/Documents/Arduino/libraries/LoRa/src -I/Users/Adama/Documents/Arduino/libraries/LiquidCrystal_I2C /private/var/folders/1w/6h9htr_90tjf5xs7bqp8s3j80000gn/T/arduino-sketch-B849C62D738F51495C99F1AC58329D60/sketch/sketch_dec3a.ino.cpp -o /private/var/folders/1w/6h9htr_90tjf5xs7bqp8s3j80000gn/T/arduino-sketch-B849C62D738F51495C99F1AC58329D60/sketch/sketch_dec3a.ino.cpp.o
/private/var/folders/1w/6h9htr_90tjf5xs7bqp8s3j80000gn/T/.arduinoIDE-unsaved2022113-635-5bazu4.tgoj8/sketch_dec3a/sketch_dec3a.ino: In function 'void setup()':
/private/var/folders/1w/6h9htr_90tjf5xs7bqp8s3j80000gn/T/.arduinoIDE-unsaved2022113-635-5bazu4.tgoj8/sketch_dec3a/sketch_dec3a.ino:13:13: error: no matching function for call to 'LiquidCrystal_I2C::begin()'
In file included from /private/var/folders/1w/6h9htr_90tjf5xs7bqp8s3j80000gn/T/.arduinoIDE-unsaved2022113-635-5bazu4.tgoj8/sketch_dec3a/sketch_dec3a.ino:5:0:
/Users/Adama/Documents/Arduino/libraries/LiquidCrystal_I2C/LiquidCrystal_I2C.h:58:8: note: candidate: void LiquidCrystal_I2C::begin(uint8_t, uint8_t, uint8_t)
   void begin(uint8_t cols, uint8_t rows, uint8_t charsize = LCD_5x8DOTS );
/Users/Adama/Documents/Arduino/libraries/LiquidCrystal_I2C/LiquidCrystal_I2C.h:58:8: note:   candidate expects 3 arguments, 0 provided
/private/var/folders/1w/6h9htr_90tjf5xs7bqp8s3j80000gn/T/.arduinoIDE-unsaved2022113-635-5bazu4.tgoj8/sketch_dec3a/sketch_dec3a.ino: In function 'void loop()':
/private/var/folders/1w/6h9htr_90tjf5xs7bqp8s3j80000gn/T/.arduinoIDE-unsaved2022113-635-5bazu4.tgoj8/sketch_dec3a/sketch_dec3a.ino:40:15: error: 'packet' was not declared in this scope
/private/var/folders/1w/6h9htr_90tjf5xs7bqp8s3j80000gn/T/.arduinoIDE-unsaved2022113-635-5bazu4.tgoj8/sketch_dec3a/sketch_dec3a.ino:40:15: note: suggested alternative: 'packetSize'
exit status 1
Compilation error: no matching function for call to 'LiquidCrystal_I2C::begin()'
and here is the LCD sketch that i first tried..
#include <Wire.h>
#include <SPI.h>
#include <LoRa.h>
  while (!Serial);
  lcd.begin();
  lcd.setCursor(0,0);
  delay(2500);
  lcd.clear();
  lcd.setCursor(0,0);
    while (1);
lcd.clear();
  if (packetSize) {
    lcd.print(packet);
    delay(2000);
If your first error was with lcd.begin(), why do add this :
What is purpose of this line and where do you found that it should be use the packet variable?
it was in my original sketch that i got working befor i tried adding the LCD..
here is the original working sketch befor i tried adding the LCD to it.
#include <SPI.h>
#include <LoRa.h>
  while (!Serial);
    while (1);
  if (packetSize) {
    // read packet
I don't know anything about LoRa. I did download the library, had a look at the LoRaReceiver example (I suspect that you based your code on that as well) and came up with the below (based on that example, not on your code). Instead of printing directly, it saves to a buffer and next prints the buffer byte by byte.
The output format might look strange to you as it is hexadecimal; you can check the values on e.g. https://www.asciitable.com/.
// packet buffer
byte packet[512];
  // if there is data
  if (packetSize)
    Serial.print(F("Received packet containing "));
    Serial.print(packetSize);
    Serial.println(F(" bytes"));
    // check if our packet buffer is large enough
    if ((uint16_t)packetSize > sizeof(packet) - 1)
      Serial.println(F("Received data too large for packet buffer"));
      // clean out what we have
        LoRa.read();
      // bail out
      return;
    // read packet
    LoRa.readBytes(packet, packetSize);
    // if you only receive text, add the below line
    // packet[packetSize] = '\0';
    for (uint16_t cnt = 0; cnt < (uint16_t)packetSize; cnt++)
      if (packet[cnt] < 0x10)
        Serial.print(F("0"));
      Serial.print(packet[cnt]);
      Serial.print(F(" "));
The 512 bytes in packet might be too big; you can make it smaller (e.g. 17, for one line on the LCD).
If the printed values are between 20 and 7F or are 0A or 0D, you have received text and printit to the LCD.
Note:
I've left setup() and global variable declarations / includes out.
Please point the the line in the sketch post#9 where do you use the packet variable?
There is no such variable.
Cool..ill give this a try and have a read through the link you have provided...your right it looks strange but im willing to learn..im 41 and all this is absolutley new to me but im enjoying the process..and i really appreciate you going out of your way and looking for a solution for me..
cheers ill give this a go..
Hi...
Yeah im not sure the only reason its there because its an example from the Lora by Sandeep Mistry library i am using whilst trying to add a i2c LCD..
There is no "packet" in the example too. You added it yourself.
If you adding the variable to the code, you must declare it first, you didn't do that, so the error.
But I still don't understand, why did you invented it.
sorry..i added it by following some tutorials i wll show you there sketch..it is in the creat.Arduino.cc tutorials.. (https://create.arduino.cc/projecthub/noneedforit/how-to-use-lora-with-arduino-22aafc)
/*feel free to contact
 * sreeramaj53@gmail.com
 * www.youtube.com/ZenoModiff
 * last updated - time 07:43 PM - date 27 may 2021
 Github Link :-- https://github.com/Zenomodiff/RFM95-LoRa-Module-Interfacing
#include <Wire.h>
#include <SPI.h>
#include <LoRa.h>
  while (!Serial);
  lcd.begin();
  lcd.setCursor(0,0);
  delay(2500);
  lcd.clear();
  if (!LoRa.begin(915E6)) {
  lcd.setCursor(0,0);
    while (1);
lcd.clear();
  if (packetSize) {
    lcd.print(packet);
    delay(2000);
looks like a typo.
There is no "packet" in the library. It won't work this way.
i might leave it out...do you think that will work...?
ill let you know.
Yeah i tried deleting "lcd.print(packet);" , it finally loaded but nothing doesnt shows up on the LCD. it only shows recieving packets on the serial monitor.
Do it prints al least a greeting message:
at the start time?
Yeah it starts off with "Lora reciever" than nothing.
