Problems understanding RS232 - CTS pin
I’ve been looking into making my ow ICSP board. The reason I want to venture into making my own in cause I want one board that I can use with both ATMEL and PIC chips while just changing the positions of a header.
Now that I got the Atmel side on the go, i started working on the PIC side. I so an interesting design and I went ahead and built it on a protoboard and it worked. However, now that I look at the schematic, I have no idea why it worked.
The schematic is below:
What I don’t understand is the CTS connection. The Prog Data pin can handle a max of 5.3V, but doesn’t the RS232 work at 12V? Wouldn’t this destroy my chip? When does CTS normally go on? Would CTS ever go high in this design?
I know, this is not completely Arduino related (thought I plan on usnig this to bootload Arduino designs and work on the Pinguino project), but I really didn’t know where else to turn.
In this design the CTS from the DB9 connector is an input, therefore you chip is safe.
darudude
To elaborate on Grumpy_Mike’s response …
Normally implemented RS-232 uses -12 V to represent a logic ‘1’ and +12 V to represent a logic ‘0’.
For communications between digital devices, such as in your implementation, a hybrid system is frequently used where RS-232 signals are implemented with digital logic levels. In this case 0 V is used to represent an RS-233 logic ‘1’ and +5 V is used to represent an RS-232 logic ‘0’.
Each of the three transistors in your circuit is acting as an inverter, so when, for example, your DTR line is +5 V representing a digital logic ‘1’, the PROG_DATA line is 0 V, representing an RS-232 logic ‘1’.
Would CTS ever go high in this design?"
Yes, when DTR goes low. But this is only +5 V via R4.
floresta
