Problems uploading Marlin firmware to Reprap Melzi 2.0 (atmega 1284P)
I am having a lot of trouble getting Marlin (or any firmware) onto my Melzi Reprap board. I am on Arduino 1.8.8 and am using Sanguino for the board. I have been using this video tutorial. At first I couldn't even burn the bootloader but then I changed from an Arduino Mega to an Uno and then it burned.
Then I try to compile and upload Marlin and if I use "arduino" as the programmer I get this:
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega1284p -carduino -PCOM6 -b57600 -D -Uflash:w:C:\Users\Trevan\AppData\Local\Temp\arduino_build_20252/Marlin.ino.hex:i
avrdude: Version 6.3-20171130
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM6
         Using Programmer              : arduino
         Overriding Baud Rate          : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x1e
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x1e
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x1e
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x1e
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x1e
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x1e
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x1e
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x1e
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x1e
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x1e
avrdude done.  Thank you.
Then I try to compile and upload Marlin and if I use "stk500v2" as the programmer I get this:
C:\Users\Trevan>"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude" -C"C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf" -v -patmega1284p -cstk500v2 -PCOM6 -b57600 -D -Uflash:w:C:\Users\Trevan\AppData\Local\Temp\arduino_build_20252/Marlin.ino.hex:i
         Using Port                    : COM6
         Using Programmer              : stk500v2
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
         AVR Part                      : ATmega1284P
         Chip Erase delay              : 55000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10   128    0 no       4096    8      0  9000  9000 0xff 0xff
           flash         65    10   256    0 yes    131072  256    512  4500  4500 0xff 0xff
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
         Programmer Type : STK500V2
         Description     : Atmel STK500 Version 2.x firmware
         Programmer Model: Unknown
this continues forever...
I have tried this at different baud rates with no difference in results. I have tried setting the jumper to usb and vreg with no difference in results. I have tried resetting the board using the button, unplugging the usb and toggling the power just as it finishes compiling with no difference in results.
Any help would be appreciated!
How did you burn the bootloader?
What I suggest is to use MightyCore
install the MightyCore Boards Manager URL and then use an in-circuit serial programming (ISP) tool to install one of its Optiboot versions. After that try to upload a sketch.
Note that, if using MightyCore, you should select Tools > Pinout > Sanguino. MightyCore's other pinout selections will not be compatible with your Melzi Reprap board.
