Problems uploading my code to the board
I am getting an error when trying to upload my code:
Arduino: 1.8.19 (Windows 10), Board: "Arduino Uno"
Sketch uses 2002 bytes (6%) of program storage space. Maximum is 32256 bytes.
Global variables use 184 bytes (8%) of dynamic memory, leaving 1864 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM6 -b115200 -D -Uflash:w:C:\Users\zacha\AppData\Local\Temp\arduino_build_475833/ClapLight.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM6
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x50
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x50
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x50
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x50
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x50
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x50
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x50
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x50
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x50
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x50
avrdude done.  Thank you.
Problem uploading to board.  See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
Not sure how to solve this as the other solutions I have seen don't work.
Restart your computer, THEN plug in the Arduino with nothing plugged into it, then try to upload. Report back.
Your other topic on the same subject deleted.
Please do not duplicate your questions as doing so wastes the time and effort of the volunteers trying to help you as they are then answering the same thing in different places.
Please create one topic only for your question and choose the forum category carefully. If you have multiple questions about the same project then please ask your questions in the one topic as the answers to one question provide useful context for the others, and also you won’t have to keep explaining your project repeatedly.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum
Thank you.
