Problems Uploading to Arduino Uno SMD
OS: Windows 10 x64 Board: Arduino Uno SMD from Maker Shed Unable to upload Supposed driver issue Error Message Displayed: avrdude: ser_open(): can't open device "\.\COM1": The system cannot find the file specified. Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions. Version of Arduino IDE: 1.6.9
I was trying to upload this code:
[Select]
  Serial.println("Hello World")
However, this came up:
Sketch uses 1,798 bytes (5%) of program storage space. Maximum is 32,256 bytes. Global variables use 212 bytes (10%) of dynamic memory, leaving 1,836 bytes for local variables. Maximum is 2,048 bytes. avrdude: ser_open(): can't open device "\.\COM1": The system cannot find the file specified.
Originally I went to the Device Manager and went to the "Ports" section to check if the board was on COM1 like the software and the error message said (see attached screenshot), and it was on COM3. So I tried to change it to COM1, still didn't work. Then I watched this video. Since the guy in the video deleted the driver in Device Manager and reinstalled it, I attempted to do the same. Except when I reconnected my Arduino it showed up under "Other Devices." Being the idiot that I am, I uninstalled it again because I thought I messed up (the COM section wasn't showing up under "Properties").
After that, disconnecting and reconnecting my board did not get a device to show up under "Ports" or "Other Devices." This week I tried again and it showed up under "Other Devices," thank God. I tried to update the driver (see attached screenshots) and Device Manager said that it was updated, and it recognized my board as well. However, when I closed out of the dialog (and even when I opened and closed Device Manager), it was still under "Other Devices" listed as "Unknown Device." I tried reinstalling the driver over and over, still didn't work. I directed it to the Arduino drivers file and I have let it search for updated software - both times it says the installation was successful.
Any help is appreciated
