Hi all!
A couple years ago, I used an Arduino board for a project in school. After re-sparking my interest and looking up some projects, I found one that interested me and seemed relatively easy to do. However, I have very little experience in C++. I didn't do any of the coding on my last project, so when I compiled this code that I got from Github (Adafruit-Programmable-Piggy-Bank/piggybank.ino at master · adafruit/Adafruit-Programmable-Piggy-Bank · GitHub) and ran into some errors, I was quite dumbfounded.
The project that I'm trying to construct is a piggy bank that accepts up to 4 coins (this code was meant for a 1 coin acceptor) and keeps track of the total amount of money along the way. The original code also includes an LED, which I am deciding to leave out. I have all of the necessary components (arduino, LCD shield, 4 coin acceptor, etc.) but when I try to compile the code, I get an error.
This is the original code:
[code]/*********************
* connect the COIN wire to digital 2
* set the side switches to "FAST" "NC"
// include the library code:
#include <Wire.h>
#include <Adafruit_MCP23017.h>
#include <Adafruit_RGBLCDShield.h>
// The shield uses the I2C SCL and SDA pins. On classic Arduinos
// this is Analog 4 and 5 so you can't use those for analogRead() anymore
// However, you can connect other I2C sensors to the I2C bus and share
// the I2C bus.
Adafruit_RGBLCDShield lcd = Adafruit_RGBLCDShield();
// These #defines make it easy to set the backlight color
#define RED 0x1
#define YELLOW 0x3
#define GREEN 0x2
#define TEAL 0x6
#define BLUE 0x4
#define VIOLET 0x5
#define WHITE 0x7
// attach coin wire to digital 2
#define COIN 2
int coins;
int brightness = 0; // how bright the LED is
int fadeAmount = 5; // how many points to fade the LED by
int fadebrightness = 0; // how bright the LED is when it's flashing
// declare pin 11 to be an output for LED:
pinMode(11, OUTPUT);
// Debugging output
// set up the LCD's number of rows and columns:
lcd.begin(16, 2);
pinMode(COIN, INPUT);
digitalWrite(COIN, HIGH); // pull up
coins = 0;
lcd.setCursor(0,0);
lcd.print(" PLEASE INSERT ");
lcd.setCursor(0,1);
lcd.print(" ONE QUARTER ");
// set the brightness of pin 11:
analogWrite(11, brightness);
// while the coin pin is low (no coin detected), do nothing
while (! digitalRead(COIN)) {
delay(1);
// while the pin is high, we'll track the length with a counter
uint8_t counter = 0;
while (digitalRead(COIN)) {
delay(1);
counter++;
Serial.print(counter);
Serial.println(" ms long pulse");
if ((counter > 60) || (counter < 20))
return;
coins++;
lcd.clear();
lcd.setCursor(0,0);
lcd.print(" OINK OINK! ");
lcd.setCursor(0,1);
lcd.print("YOU HAVE $");
lcd.print(coins*.25);
lcd.print(" ");
// loop through to flash the LED
fadebrightness = brightness;
for (int i = brightness; i < 510; i+=5) {
// turn the pin on:
analogWrite(11, fadebrightness);
fadebrightness = fadebrightness + fadeAmount;
delay(20);
// reverse the direction of the fading at the ends of the fade:
if (fadebrightness == 0 || fadebrightness == 255) {
fadeAmount = -fadeAmount;
brightness = brightness + 5;
[/code]
And these are the errors that I get:
piggy_bank_code:19: error: 'Adafruit_RGBLCDShield' does not name a type
piggy_bank_code.ino: In function 'void setup()':
piggy_bank_code:43: error: 'lcd' was not declared in this scope
piggy_bank_code.ino: In function 'void loop()':
piggy_bank_code:51: error: 'lcd' was not declared in this scope
Adafruit_RGBLCDShield.ino: At global scope:
Adafruit_RGBLCDShield:106: error: 'Adafruit_MCP23017' does not name a type
Leaving out the code for the LED is simple enough, and I could probably tinker with the coding for 1 coin to allow for 4 different coins, but these errors are really confusing me. I've googled each of the error messages but like I said, I have very little C++ experience, so I'm not sure if the little information that I am finding is helpful at all. Any help would be extremely appreciated. Thank you!
-Rex
