Problems using EasyVR shield to turn on a lamp
Hello! I am new to Arduino and my first project is to turn on a lamp with vocal commands using EasyVR Shield. I am using the newest Arduino Uno.
Basically, the design goes like this. I have the EasyVR Shield attached to the Arduino Uno, which is connected by a USB cable to my computer. This is connected to a PowerTail Switch (this is the exact one I’m using: http://www.powerswitchtail.com/Pages/default.aspx), which in turn is connected to the lamp and outlet.
I found a tutorial on how to do that here: http://jacksondolan.com/blag/2013/10/16/bringing-jarvis-home/
However, for some reason the lamp is simply not turning on. I know it recognizes my commands because I can see them in the serial monitor. I have attached my code and an image of the connections below in case my connections do not match my code, which I suspect is the problem. Most of the code is generated by the EasyVR Commander, and I have done as the link above says.
#if defined(ARDUINO) && ARDUINO >= 100
  #include "Arduino.h"
  #include "SoftwareSerial.h"
  SoftwareSerial port(12,13);
#else // Arduino 0022 - use modified NewSoftSerial
  #include "WProgram.h"
  #include "NewSoftSerial.h"
  NewSoftSerial port(12,13);
#endif
#include "EasyVR.h"
EasyVR easyvr(port);
//Groups and Commands
enum Groups
  GROUP_0  = 0,
  GROUP_1  = 1,
enum Group0
  G0_ARDUINO = 0,
enum Group1
  G1_LAMP = 0,
  G1_GOODNIGHT = 1,
EasyVRBridge bridge;
int8_t group, idx;
const int powerPin = A0;
boolean powerOn = false;
  // bridge mode?
  if (bridge.check())
    cli();
    bridge.loop(0, 1, 12, 13);
  // run normally
  port.begin(9600);
  if (!easyvr.detect())
    Serial.println("EasyVR not detected!");
    for (;;);
  easyvr.setPinOutput(EasyVR::IO1, LOW);
  Serial.println("EasyVR detected!");
  easyvr.setTimeout(5);
  easyvr.setLanguage(0);
  group = EasyVR::TRIGGER; //<-- start group (customize)
  pinMode(powerPin, OUTPUT);
  digitalWrite(powerPin, HIGH);
  pinMode(13, OUTPUT);
  digitalWrite(13, LOW);
void action();
  easyvr.setPinOutput(EasyVR::IO1, HIGH); // LED on (listening)
  Serial.print("Say a command in Group ");
  Serial.println(group);
  easyvr.recognizeCommand(group);
  do
    // can do some processing while waiting for a spoken command
  while (!easyvr.hasFinished());
  easyvr.setPinOutput(EasyVR::IO1, LOW); // LED off
  idx = easyvr.getWord();
  if (idx >= 0)
    // built-in trigger (ROBOT)
    // group = GROUP_X; <-- jump to another group X
    return;
  idx = easyvr.getCommand();
  if (idx >= 0)
    // print debug message
    uint8_t train = 0;
    char name[32];
    Serial.print("Command: ");
    Serial.print(idx);
    if (easyvr.dumpCommand(group, idx, name, train))
      Serial.print(" = ");
      Serial.println(name);
    easyvr.playSound(0, EasyVR::VOL_FULL);
    // perform some action
    action();
  else // errors or timeout
    if (easyvr.isTimeout())
      Serial.println("Timed out, try again...");
    int16_t err = easyvr.getError();
    if (err >= 0)
      Serial.print("Error ");
      Serial.println(err, HEX);
void action()
    switch (group)
    case GROUP_0:
      switch (idx)
      case G0_ARDUINO:
        // write your action code here
        group = GROUP_1;
        // group = GROUP_X; <-- or jump to another group X for composite commands
    case GROUP_1:
      switch (idx)
      case G1_LAMP:
      /*Serial.println("In Light");
      powerOn = !powerOn;
      if (powerOn) {
        Serial.println("Power On");
        digitalWrite(powerPin, LOW);
        digitalWrite(13, HIGH);
      else {
        Serial.println("Power Off");
      */group = GROUP_1;
      case G1_GOODNIGHT:
        group = GROUP_0
        digitalWrite(13, LOW);/*
        digitalWrite(13, LOW); */
I have attached a picture of the wiring too. The first green wire is going to 5V (just in case the connection is covered up).
Thanks in advance for the help!
Hey -
I'm new to both of these as well, and have an interest in a similar project, did you ever figure out what was wrong?
http://forum.arduino.cc/index.php?topic=209913.msg1542874#msg1542874
