Hello everyone,
I built a led matrix using WS2812B Rgb strips, a simple 15x10 design, externally powered.
I'd like to control them using an arduino lilypad (not authentic).
I wrote a code to make a "2" appear on the matrix, and it works perfectly if used with an arduino uno.
However when i try to use the same code with the lilypad (changing of course the setting in the ide from arduino uno to lilypad), it doesn't work.
The matrix light up but it shows what seems to be a random pattern, changing over time.
The lilypad itself seems to work nicely with other programs that don't use the matrix but just a couple of leds.
I used the FastLED 3.4.0 library `.
Do you have any tips on what could be the problem?
Thanks in advance to everyone.
Carlo
#include <avr/pgmspace.h> // Needed to store stuff in Flash using PROGMEM
#include <FastLED.h> // Fastled library to control the LEDs
// How many leds are connected?
#define NUM_LEDS 150
// Define the Data Pin
#define DATA_PIN 3 // Connected to the data pin of the first LED strip
// Define the array of leds
CRGB leds[NUM_LEDS];
// Create the array of retro arcade characters and store it in Flash memory
const long TWO[] PROGMEM =
0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x0000FF00, 0x0000FF00, 0x0000FF00, 0x0000FF00, 0x0000FF00, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000,
0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x0000FF00, 0x0000FF00, 0x0000FF00, 0x0000FF00, 0x0000FF00, 0x0000FF00, 0x0000FF00, 0x00000000, 0x00000000, 0x00000000, 0x00000000,
0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x0000FF00, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x0000FF00, 0x0000FF00, 0x00000000, 0x00000000, 0x00000000, 0x00000000,
0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x0000FF00, 0x0000FF00, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000,
0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x0000FF00, 0x0000FF00, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000,
0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x0000FF00, 0x0000FF00, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000,
FastLED.addLeds<NEOPIXEL,DATA_PIN>(leds, NUM_LEDS); // Init of the Fastled library
FastLED.setBrightness(50);
FastLED.clear();
for(int i = 0; i < NUM_LEDS; i++)
leds[i] = pgm_read_dword(&(TWO[i])); // Read array from Flash
FastLED.show();
