the scope of my project is to measure the frequency of a square wave oszillator
by measuring the time between two RISING interrupts on digital pin 2 of the arduino uno.
The problem is that millis returns the same value on both interrupts.
My code is meant to do the following:
every interrupt increments Interrupt_flag
if Interrupt_flag is 1 the main loop gets a value from millis and writes it to tol_int
if Interrupt_flag is 2 the main loop calls get_Hertz
get_Hertz stops the interrupt to not be disturbed while working
now it gets a new value from millis to do the math for determining the frequency
after writing the frequency to a LCD it writes a 0 to Interrupt_flag and starts the Interrupts again
The problem is that both millis values are the same. As if main loop does both cases at once.
What is wrong with my code? Or is it a general design failure?
Best Regards
Basti
/* Frequenzmessung eines Rechtecksignals mittels externen Interrupts */
// The display communicates using SPI, so include the library:
#include <SPI.h>
// LCD Starting Byte:
const byte wcinit = 0b00011111; // Initialisierungs-Byte zum Senden eines LCD-Kommandos.
const byte wzinit = 0b01011111; // Initialisierungs-Byte zum Senden eines Zeichens an das LCD.
// Messwert in Millisekunden als globale Variable
unsigned long tol_int = 0;
// Interrupt_flag
byte Interrupt_flag = 0;
// Start the SPI library:
SPI.begin();
// Configure SPI
SPI.setBitOrder(LSBFIRST);
SPI.setClockDivider(SPI_CLOCK_DIV64);
SPI.setDataMode(SPI_MODE3);
// Configure LCD
delay(20);
// 8Bit Bus, Extended Function Set ein um auf 4 Zeilen Mode zu gehen
LCD_write(0b00110100,0);
delay(2);
// 4 Zeilen 5 Dot Font Mode
LCD_write(0b00001001,0);
delay(2);
// 8Bit Bus, Extended Fuction Set aus
LCD_write(0b00110000,0);
delay(2);
// Display / Cursor on, Cursor blink
LCD_write(0b00001111,0);
delay(2);
// Clear Display
LCD_write(0b00000001,0);
delay(2);
// Cursor Auto-Increment
LCD_write(0b00000110,0);
//Configure Interrupt
pinMode(2, INPUT);
attachInterrupt(0, set_Interrupt_flag, RISING);
switch (Interrupt_flag) {
case 1:
tol_int = millis(); //time of first interrupt
case 2:
get_Hertz(); //get time of second interrupt and calculate the frequency
default:
void get_Hertz()
noInterrupts(); //disable interrupts
LCD_write(0b10000000,0); //clear LCD
unsigned long get_time = millis(); //get time of second interrupt
char dtostrfbuffer[4];
unsigned long period = get_time - tol_int; //do some math
for (int i = 0; i <= String(tol_int).length() - 1 ; i++) //write millis of first interrupt to LCD
LCD_write(String(tol_int)[i],1);
LCD_write(0b10100000,0);
for (int i = 0; i <= String(get_time).length() - 1 ; i++) //write millis of second interrupt to LCD
LCD_write(String(get_time)[i],1);
/*for (int i = 0; i <= String(period).length() - 1 ; i++) //write period in ms to LCD
LCD_write(String(period)[i],1);
LCD_write(0b10100000,0);*/
float frequ = 1000 / period; //some math
dtostrf(frequ, 2, 1, dtostrfbuffer); //Float to char array
String Sfrequ = String(dtostrfbuffer) + " Hz";
/*for (int i = 0; i <= Sfrequ.length() - 1 ; i++) //write frequency to LCD
LCD_write(Sfrequ[i],1);
Interrupt_flag = 0; //reset Interrupt_flag
interrupts(); //enable interrupts again
void set_Interrupt_flag()
Interrupt_flag += 1;
void LCD_write(byte data, byte RS)
// Daten in lowdat und hidat aufteilen
byte lowdat = data & 0b00001111;
byte hidat = data >> 4 ;
// initialize write RS = 0 Kommando, RS = 1 Zeichen
if ( RS == 0) SPI.transfer(wcinit);
else SPI.transfer(wzinit);
SPI.transfer(lowdat); // write lower data 0 0 0 0 D3 D2 D1 D0
SPI.transfer(hidat); // write higher data 0 0 0 0 D7 D6 D5 D4
delay(2);
