Hey everybody, I am building a larger program in which I divide my code into several classes. Today I wanted to add a new class named WiFiServer
. This class should handle everything which is related to manipulating my data and send it (via post-request) to my own server.
Since today, I had a few classes:
- class Battery
- class WriterReader
- class FileSystem
I was using the <Streaming.h> file inside the
To solve the problem I need to remove the include directive from the *.ino file and from the WiFiServer.cpp file. However, I would like to keep the Serial output in the way we do it in c++.
If I include the <Streaming.h> file into the WiFiServer.cpp file, I get the following error:
In file included from /home/shorty/DIY/Arduino/DIY-BatteryCharger/DIYCharger/src/wifiServer/wifiServer.cpp:14:
/home/shorty/.arduino15/packages/esp8266/hardware/esp8266/3.0.2/cores/esp8266/StreamString.h: In member function 'virtual int S2Stream::read(uint8_t*, size_t)':
/home/shorty/DIY/Arduino/libraries/Streaming/src/Streaming.h:74:18: error: expected unqualified-id before '(' token
74 | #define min(a,b) ((a)<(b)?(a):(b))
/home/shorty/.arduino15/packages/esp8266/hardware/esp8266/3.0.2/cores/esp8266/StreamString.h:89:29: note: in expansion of macro 'min'
89 | size_t l = std::min(len, (size_t)string->length());
/home/shorty/.arduino15/packages/esp8266/hardware/esp8266/3.0.2/cores/esp8266/StreamString.h:101:25: note: in expansion of macro 'min'
101 | size_t l = std::min(len, (size_t)(string->length() - peekPointer));
/home/shorty/.arduino15/packages/esp8266/hardware/esp8266/3.0.2/cores/esp8266/StreamString.h: In member function 'virtual void S2Stream::peekConsume(size_t)':
/home/shorty/.arduino15/packages/esp8266/hardware/esp8266/3.0.2/cores/esp8266/StreamString.h:183:32: note: in expansion of macro 'min'
183 | peekPointer = std::min((size_t)string->length(), peekPointer + consume);
As an example. The WiFiServer header file looks as follows:
|| \\ || \\ // | Project: BatteryCharger using D1 Wemos
|| || || \\// | Webiste: https://Holzmann-cfd.com
|| // || || | Copyright (C) 2022 Tobias Holzmann
License
This file is part of the BatteryCharger DIY project and is distributed
under the terms of the GNU General Public License version 3
Description
This class inherits all functions that are used to send the measeurement
data to the DIY.holzmann-cfd.com websever which stores the data on a
mySQL database.
SourceFiles
wifiServer.cpp
#ifndef wifiServer_h
#define wifiServer_h
#include <ESP8266WiFi.h>
#include <ESP8266HTTPClient.h>
Class WifiServer Declaration
class WifiServer
// Private class data
// WiFi SSID
const String SSID_;
// WiFi password
const String password_;
// Url to which we want to connect
const String URL_{"https://DIY.Holzmann-cfd.com"};
public:
// Constructor
WifiServer(const String, const String);
// Destroctor
~WifiServer();
// Public Setter Functions
// Public Return Functions
// Public Member Functions
// Connect to WiFi
bool connect() const;
// Disconnect the WiFi
bool disconnect() const;
private:
// Private Member Functions
#endif
And the source file:
License
#include <Streaming.h>
#include "wifiServer.h"
// * * * * * * * * * * * * * * * * Constructors * * * * * * * * * * * * * * ///
WifiServer::WifiServer(const String SSID, const String password)
SSID_(SSID),
password_(password)
WifiServer::~WifiServer()
// * * * * * * * * * * * * Public Member Functions * * * * * * * * * * * * * //
bool WifiServer::connect() const
WiFi.begin(SSID_, password_);
// Try 5 times
int n = 0;
while (WiFi.status() != WL_CONNECTED)
Serial.println("Waiting for WiFi to be connected");
n++;
if (n == 5)
if (WiFi.status() != WL_CONNECTED)
return false;
return true;
bool WifiServer::disconnect() const
return false;
// * * * * * * * * * * * * Private Return Functions * * * * * * * * * * * * //
Okay, one solution is to avoid the <Streaming.h> inclusion. Anyhow, I was expecting that I am implementing the different libraries (header files) correctly.
Tobi
PS: Project is given here (but not with the latest branch I am working on):
