Hi. Very new to Arduino & coding so please bare with me.
I have built a Water level monitoring system for use with my outside water tanks. It uses an ultrasonic detector and a Wemos Mini D1 for wifi communication. I have added a DeepSleep function to save battery power. The current code sets DeepSleep for 2 minutes and all works well however if I try and extend the DeepSleep time beyond 2 minutes, it seems the Wemos Mini D1 doesn't want to wake up. I have tried three, five, ten minutes but the system remains offline. Anything up. to 2 minutes works great. What am I doing wrong?
Code listed below (apologies if it is clunky).
// Template ID, Device Name and Auth Token are provided by the Blynk.Cloud
// See the Device Info tab, or Template settings
#define BLYNK_TEMPLATE_ID "XXXXXXXXXXXXXX"
#define BLYNK_DEVICE_NAME "House Water tank"
#define BLYNK_AUTH_TOKEN "XXXXXXXXXXXXXXXXX"
// Comment this out to disable prints and save space
#define BLYNK_PRINT Serial
#include <ESP8266WiFi.h>
#include <BlynkSimpleEsp8266.h>
#define trig D5 // Trig pin
#define echo D6
char auth[] = BLYNK_AUTH_TOKEN;
int depth = 247.5; //depthof tank
int r = 175.0; // radius of tank in cm
int volume; // capacity in liters
unsigned int raw=0;
float volt=0.0;
float bat_percentage=0.0;
int analogInPin = A0;
// Your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = "XXXXXXXX";
char pass[] = "XXXXXXXXXXXXXXXXXX";
BlynkTimer timer;
void waterlevel()
digitalWrite(trig, LOW);
delayMicroseconds(2);
digitalWrite(trig, HIGH);
delayMicroseconds(10);
long t = pulseIn(echo, HIGH);
long cm = t / 29 / 2;
Serial.println(cm);
long level= depth-cm;
if (level<0)
level=0;
long vol = level;
Serial.println(level);
level = map(level,0,depth-27.5,0,100);
Blynk.virtualWrite(V0, level);
long v = ((3.14*(r*r))*(vol)); // formula to calculate volume in cubic cm
long volume = v/1000; // final capacity in liters
Serial.println(volume);
Blynk.virtualWrite(V1, volume);
delay(200);
raw = analogRead(A0);
volt=raw/1023.0;
volt=volt*4.2;
Serial.println(volt);
Blynk.virtualWrite(V2, volt);
delay(200);
ESP.deepSleep(120e6);
#define BLYNK_AUTH_TOKEN "XXXXXXXXXXXXXXXXXXXXXXXXX"
#define echo D6
int depth = 240.0; //depthof tank
unsigned int raw=0;
float volt=0.0;
char pass[] = "XXXXXXXXXXXXX";
BlynkTimer timer;
void waterlevel()
Serial.println(cm);
if (level<0)
level=0;
long vol = level;
level = map(level,0,depth,0,90);
delay(200);
volt=raw/1023.0;
volt=volt*4.2;
delay(200);
pinMode(trig, OUTPUT);
pinMode(echo, INPUT);
pinMode(A0, INPUT);
Blynk.begin(auth, ssid, pass);
timer.setInterval(10L, waterlevel);
Blynk.run();
timer.run();
Can you properly line out your code (in IDE hit ctrl-T)?
Only one statement is dependent on your if()?
Or should there be a block of code {} there?
You realize a long is an integer? And that you loose precision upon division?
