Good afternoon dear community. I am new to the field, even though I have anime anemometer, the programming of the anemometer is included, however, when I try to modify the sketch and upload it I get the message in the serial: ERROR ON OPENING THE FILE.
I have tried to format the memory in FAT32, change the code but nothing works for me, I do not know what else to do. It is for this reason that I appeal to your support.
This is the code that I have been working on based on contributions from third parties:
#include <SPI.h>
#include <SD.h>
#include <Wire.h>
#include "RTClib.h"
const int chipSelect = 10; //cs or the save select pin from the sd shield is connected to 10.
RTC_DS1307 RTC;
//------------------------------------ ANEMOMETRO ------------------------------------
// --- Constantes ---
const float pi = 3.14159265; //Número de pi
int period = 1000; //Tempo de medida(miliseconds)
int delaytime = 1000; //Invervalo entre as amostras (miliseconds)
int radius = 147; //Raio do anemometro(mm)
// --- Variáveis Globais ---
//unsigned int Sample = 0; //Armazena o número de amostras
unsigned int counter = 0; //Contador para o sensor
unsigned int RPM = 0; //Rotações por minuto
//float speedwind ; //Velocidade do vento (m/s)
float windspeed ; //Velocidade do vento (m/s)
//int led=3;
File dataFile;
//DateTime now;
void setup () {
//pinMode(led, OUTPUT);
pinMode(2, INPUT); //configura o digital 2 como entrada
digitalWrite(2, HIGH); //internall pull-up active
//setup clock
Wire.begin();
RTC.begin();
//check or the Real Time Clock is on
if (! RTC.isrunning()) {
Serial.println("RTC is NOT running!");
// following line sets the RTC to the date & time this sketch was compiled
// uncomment it & upload to set the time, date and start run the RTC!
RTC.adjust(DateTime(__DATE__, __TIME__));
//setup SD card
Serial.print("Initializing SD card...");
// see if the SD card is present and can be initialized:
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
// don't do anything more:
return;
Serial.println("card initialized.");
/* //write down the date (year / month / day prints only the start, so if the logger runs for sevenal days you only findt the start back at the begin.
now = RTC.now();
dataFile = SD.open("met.txt", FILE_WRITE);
dataFile.print("Start logging on: ");
dataFile.print(now.year(),DEC);
dataFile.print('/');
dataFile.print(now.month(),DEC);
dataFile.print(now.day(),DEC);
dataFile.println(" ");
dataFile.println("Time Counter RPM Velocidad del viento (m/s)");
// dataFile.close();
void loop (void){
//read the time
DateTime now = RTC.now();
//open file to log data in.
// if the file is available, write to it:
// log the temperature and time.
if (dataFile) {
dataFile.print(now.hour(),DEC);
dataFile.print(":");
dataFile.print(now.minute(),DEC);
dataFile.print(now.second(),DEC);
Serial.print(" ");
//Sample++;
// dataFile.print(Sample);
dataFile.print("Empezo la medicion...");
//windvelocity();
dataFile.println(" Terminado.");
dataFile.print(" ");
dataFile.print(counter);
//RPMcalc();
dataFile.print(RPM);
dataFile.println(windspeed);
dataFile.close();
// print to the serial port too:
//Serial.println("data stored");
/* digitalWrite(led, HIGH); // enciende el LED (HIGH es el nivel de voltaje)
delay(100); // espera un segundo
digitalWrite(led, LOW);
delay(100);
// read wind
Serial.print(now.hour(),DEC);
Serial.print(":");
Serial.print(now.minute(),DEC);
Serial.print(":");
Serial.print(now.second(),DEC);
Serial.print(" ");
//Sample++;
//Serial.print(Sample);
Serial.print("Empezo la medicion...");
windvelocity();
Serial.println(" Terminado.");
Serial.print(":");
Serial.print(":");
Serial.print(" ");
Serial.print("Counter: ");
Serial.print(counter);
Serial.print("; RPM: ");
RPMcalc();
Serial.print(RPM);
Serial.print("; Velocidad del viento: ");
WindSpeed();
Serial.print(windspeed);
Serial.print(" m/s ");
// if the file isn't open, pop up an error:
else {
Serial.println("error al abrir");
//delay(1000); // this will log the temperature every second.
delay(delaytime);
//Função para medir velocidade do vento
void windvelocity()
// speedwind = 0;
windspeed = 0;
counter = 0;
attachInterrupt(0, addcount, RISING);
unsigned long millis();
long startTime = millis();
while(millis() < startTime + period) {}
//Função para calcular o RPM
void RPMcalc()
RPM=((counter)*60)/(period/1000); // Calculate revolutions per minute (RPM)
//Velocidade do vento em m/s
void WindSpeed()
windspeed = ((4 * pi * radius * RPM)/60) / 1000; //Calcula a velocidade do vento em m/s
} //end WindSpeed
//Velocidade do vento em km/h
/*void SpeedWind()
speedwind = (((4 * pi * radius * RPM)/60) / 1000)*3.6; //Calcula velocidade do vento em km/h
} //end SpeedWind
//Incrementa contador
void addcount()
counter++;
