Problems when uploading using "Upload using programmer"
So I have a SAMD21G18A chip and I uploaded an arduino bootloader (MKR GSM 1400) and programmed the board using "Upload using programmer". This worked fine for about a week, but now it suddenly stopped working. The upload process is successful but the code doesn't run. If I upload over USB it's fine, furthermore if I upload in atmel studio it's fine aswell. Any ideas what could be causing this?
Bugs in the code You didn't post.
I tried uploading basic codes that just print to serial and the problem is the same. I starded to get this error tho (when uploading using programmer) "Error: at91samd21g18.cpu -- clearing lockup after double fault", so i'm not sure if i bricked it somehow.
Atmel communityHere ?
OK I figured out what the problem is, i needed to change the upload speed to be the same as in atmel studio (2MHz in atmel 400kHz using arduino). The speed is defined in this file: "...vendor\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7\share\openocd\scripts\target\at91samdXX.cfg". In here you will find "adapter_khz" i just set it to 2000 kHz and everything works again.
