Problems when using 2 Keypads with i2ckeypad Library.
Hello,
I have 2 x 4x4 Keypads that are connected to two Seperate PCF8574AP Chips. Each set to a different address.
I’m using this library:
http://arduino.cc/playground/Main/I2CPortExpanderAndKeypads
The Library works perfectly fine when using only one instance (One Keypad).
At first I couldn’t get the library to work at all with two instances. So I made a small modification to the Library as follows:
Changed (i2ckeypad.h):
private:
  void pcf8574_write(int, int);
  int pcf8574_byte_read(int);
TO (i2ckeypad.h):
private:
  int pcf8574_i2c_addr;
Then in “i2ckeypad.cpp”, I commented out the line:
// PCF8574 i2c address
// int pcf8574_i2c_addr;
It now works “somewhat” with two instances.
i am now able to access both keypads, however under the serial monitor, when I press a key once, the key is displays over 20 times per keypress. It should only display each keypress once.
I also noticed if I add a 30ms delay between the checking the two instance, the amount of times it shows in the serial monitor is cut down from 20 to about 5 displays per keypress.
I have attached a zip file with the modified library and a working (One Instance) and non-working (Two Instances) example sketch as well as pictures of the Serial Terminal Output.
Does anybody have any idea how to fix this issue?
i2ckeypad.zip (70.5 KB)
// Current search row
static int row_select;
// Current data set in PCF8574
static int current_data;
A library shouldn't have static data if you are making multiple instances. It will "remember" the row, and then when you call it for the second keypad, get confused.
I would move both of those into the class.
I got it working by doing what you suggested, plus one other modification.
I had to also move “static int temp_key;” into the class to make it work!
Seems to work good now!
