Problems when using HC-12 wireless module with servos
Hi, I am using an Arduino Nano, and am having an issue with SG90 servos (Servo.h library) when used with the HC-12 wireless module (SoftwareSerial.h library). The servos move very suddenly every time I call the .print() or .write() functions of the HC-12. I have done some research and think that the issue may be because both the servos and HC-12 use the same timer, although I am not sure what this means or what I can do to fix my issue.
Any help would be great, Thanks.
I think that some people have solved that problem by using the ServoTimer2 library instead of Servo.
Thanks, I used the 'PWMServo' library and it worked.
