Problems when using <Servo.h> and <PulseSensorPlayground.h> liblaries
I am on project which uses servo motor and pulse sensor.
But whenever i try to comfile, i encounter an error like this.
libraries\Servo\avr\Servo.cpp.o (symbol from plugin): In function ServoCount': (.text+0x0): multiple definition of __vector_11'
sketch\sketch_dec02a.ino.cpp.o (symbol from plugin):(.text+0x0): first defined here
collect2.exe: error: ld returned 1 exit status
exit status 1
This is the code required to solve:
#define USE_ARDUINO_INTERRUPTS true
#pragma once
#include <PulseSensorPlayground.h>
#include <Servo.h>
Servo servo;
PulseSensorPlayground pulseSensor;
const int PulseWire = 0;
const int RED = 3;
const int BLUE = 6;
const int START = 7;
const int RESET = 8;
const int servoPin = 9;
const int buttonpin = 10;
const int LED13 = 13;
const int speakerpin = 12;
const int GSR = A2;
int Threshold = 550;
int sensorValue = 0;
int gsr_average = 0;
int skin;// 피부전도율
int beat;//심장박동
int isLie = 0; // 거짓말일 경우 1
int gsrRange = 100; // gsr범위, 변경 가능
int lieNum = 0; //거짓말 횟수
int angle = 0;
void GSR_BPM(int sB, int rB)
  long GSR_sum = 0;
  int myBPM = pulseSensor.getBeatsPerMinute();  // Calls function on our pulseSensor object that returns BPM as an "int".
  int BPM_sum = 0;
  int BPM_avg,Bpm_range;
  int diff_BPM = BPM_avg - beat;   //심장박동수는 증가하기 때문에 음수 고려x
  int BPM_range = BPM_avg / 11;
  if (sB == 1) // start버튼 클릭
    if (pulseSensor.sawStartOfBeat()&& myBPM > 50 && myBPM < 160 )
      delay(3000);
       Serial.println("  A HeartBeat Happened ! ");
       Serial.print("BPM: ");
       Serial.println(myBPM);
       for(int i = 0 ; i < 10; i++)
          BPM_sum += myBPM;
          sensorValue = analogRead(GSR);
          GSR_sum += sensorValue;
          delay(30);
       BPM_avg = BPM_sum / 10;
       gsr_average = GSR_sum / 10;
   int GSR_diff = gsr_average - skin;
   if (-gsrRange > GSR_diff || GSR_diff > gsrRange)
    isLie = 1;
    return;
   else if (BPM_range < diff_BPM)
     isLie = 1;
     return;
    return;
  if (rB == 1) // reset버튼 클릭
      delay(5000); // 안정 기간
      for (int i = 0; i < 10; i++)
      BPM_sum += myBPM;
      delay(30);
   beat = BPM_avg;
   gsr_average = GSR_sum/10;
   skin = gsr_average; // 피부 전도율 기록
   return;
 void setColor(int r,int g, int b)
  analogWrite(RED,r);
  analogWrite(BLUE,b);
  delay(1500);
  return;
void servoM(int n)
  if (n == 1)
    servo.write(5);
    for (angle = 5; angle < 30; angle++)
      servo.write(angle);
      delay(20);
  else if (n == 2)
    servo.write(30);
    for (angle = 30; angle < 55; angle++)
      servo.write(angle);
      delay(20);
  else if (n == 3)
    servo.write(0);
    servo.write(100);
  return;
  pinMode(START, INPUT);
  pinMode(RESET, INPUT);
  pulseSensor.analogInput(PulseWire);
  //LED는 일단 냅둠
  pulseSensor.blinkOnPulse(LED13);
  pulseSensor.setThreshold(Threshold);
  servo.attach(servoPin);
  pinMode(buttonpin,INPUT);
  pinMode(RED,OUTPUT);
  pinMode(BLUE,OUTPUT);
  if (pulseSensor.begin()) {
    Serial.println("START!");  //This prints one time at Arduino power-up,  or on Arduino reset.
  int startB = digitalRead(START);
  int resetB = digitalRead(RESET);
  if (startB == 1)
    GSR_BPM(1, 0);
    if (isLie == 1) // LED, 알림 소리, 서보 모터
      lieNum++;
      tone(speakerpin,500,500);
      setColor(255, 0, 0);
      servoM(lieNum);
      setColor(0, 0, 0);
    else //(isLie == 0) -> LED
      setColor(0, 0, 255);
      setColor(0, 0, 0);
  if (resetB == 1)
    GSR_BPM(0, 1);
  //if (게임 종료(3번 거짓말) == 1) -> 게임 종료, reset버튼으로 다시 시작. 거짓말 횟수 초기화 필요
  if (lieNum == 3)
    tone(speakerpin, 500, 500);
    setColor(200, 0, 200);
    lieNum = 0;
  startB = 0; // 초기화
  resetB = 0; // 초기화
  isLie = 0;
That means that two libraries are both using the same timer interrupt. I suggest you find the ServoTimer2 library and use that in place of the Servo library.
