Here is the code:
#include "MatrixDisplay.h"
#include "DisplayToolbox.h"
#include "font.h"
#define DEMOTIME 30000 // 30 seconds max on each demo is enough.
#define DISPDELAY 100 // Each "display" lasts this long
#define LONGDELAY 1000 // This delay BETWEEN demos
// Macro to make it the initDisplay function a little easier to understand
#define setMaster(dispNum, CSPin) initDisplay(dispNum,CSPin,true)
#define setSlave(dispNum, CSPin) initDisplay(dispNum,CSPin,false)
// 4 = Number of displays
// Data = 10/
// WR == 11
// True. Do you want a shadow buffer? (A scratch pad)
// Init Matrix
MatrixDisplay disp(4,11,10, true);
// Pass a copy of the display into the toolbox
DisplayToolbox toolbox(&disp);
// Prepare boundaries
uint8_t X_MAX = 0;
uint8_t Y_MAX = 0;
// Fetch bounds (dynamically work out how large this display is)
X_MAX = disp.getDisplayCount() * (disp.getDisplayWidth()-1)+1;
Y_MAX = disp.getDisplayHeight();
// Prepare displays
disp.setMaster(0,4);
// disp.setSlave(1,5);
// disp.setSlave(2,6);
// disp.setSlave(3,7);
demoText(); // Bouncy hello
demoBouncyCircle();
demo_bouncyline(); // Bouncy line
demo_life(); // Basic life demo
* demo_life
* Run the "life" game for a while, demonstrating the
* ability of the AVR to update every pixle of the display
* after having done some computation to figure out the new
* value. Also demonstrates the use of the snapshot ram.
void demo_life ()
byte x,y, neighbors, newval;
toolbox.setPixel(10,3,1); // Plant an "acorn"; a simple pattern that
toolbox.setPixel(12,4,1); // grows for quite a while..
toolbox.setPixel(9,5,1);
toolbox.setPixel(10,5,1);
toolbox.setPixel(13,5,1);
toolbox.setPixel(14,5,1);
toolbox.setPixel(15,5,1);
delay(LONGDELAY); // Play life
disp.copyBuffer(); // Copy the back buffer into the shadow buffer (basically create a backup of the CURRENT display)
for (int i=0; i < (DEMOTIME/DISPDELAY)/4; i++) {
for (x=1; x < X_MAX; x++) {
for (y=1; y < Y_MAX; y++) {
neighbors = toolbox.getPixel(x, y+1, true) +
toolbox.getPixel(x, y-1, true) +
toolbox.getPixel(x+1, y, true) +
toolbox.getPixel(x+1, y+1, true) +
toolbox.getPixel(x+1, y-1, true) +
toolbox.getPixel(x-1, y, true) +
toolbox.getPixel(x-1, y+1, true) +
toolbox.getPixel(x-1, y-1, true);
switch (neighbors) {
case 0:
case 1:
newval = 0; // death by loneliness
case 2:
newval = toolbox.getPixel(x,y, true); // Fetch pixel from the SHADOW buffer
break; // remains the same
case 3:
newval = 1;
default:
newval = 0; // death by overcrowding
toolbox.setPixel(x,y, newval);
// Write out display
disp.syncDisplays();
// Copy buffer
delay(DISPDELAY);
* demo_bouncyline
* Do the classic "bouncing line" demo, where the endpoints of a line
* move independently and bounce off the edges of the display.
* This should demonstrate (more or less) the performance limits of
* the line drawing function.
void demo_bouncyline ()
char x1,y1, x2,y2, dx1, dy1, dx2, dy2;
disp.clear();
x1 = random(0,X_MAX);
x2 = random(0,X_MAX);
y1 = random(0,Y_MAX);
y2 = random(0,Y_MAX);
dx1 = random(1,4);
dx2 = random(1,4);
dy1 = random(1,4);
dy2 = random(1,4);
for (int i=0; i < DEMOTIME/DISPDELAY; i++) {
toolbox.drawLine(x1,y1, x2,y2, 1);
delay(DISPDELAY);
toolbox.drawLine(x1,y1, x2,y2, 0);
x1 += dx1;
if (x1 > X_MAX) {
x1 = X_MAX;
dx1 = -random(1,4);
else if (x1 < 0) {
x1 = 0;
dx1 = random(1,4);
x2 += dx2;
if (x2 > X_MAX) {
x2 = X_MAX;
dx2 = -random(1,4);
else if (x2 < 0) {
x2 = 0;
dx2 = random(1,4);
y1 += dy1;
if (y1 > Y_MAX) {
y1 = Y_MAX;
dy1 = -random(1,3);
else if (y1 < 0) {
y1 = 0;
dy1 = random(1,3);
y2 += dy2;
if (y2 > Y_MAX) {
y2 = Y_MAX;
dy2 = -random(1,3);
else if (y2 < 0) {
y2 = 0;
dy2 = random(1,3);
// Text bouncing around
void demoText()
int y=Y_MAX-7;
int x=X_MAX;
boolean textDir = false;
boolean textRight = false;
if(y<=0) textDir = true;
else if(y>=(Y_MAX-7)) textDir = false;
if(x>=X_MAX) textRight = false;
else if(x<=0) textRight = true;
if(textDir) y++;
else y--;
if(textRight) x++;
else x--;
drawString(x,y,"Hello");
delay(100);
disp.clear();
// Small circle bouncing around the bounds
void demoBouncyCircle()
int radius = 3;
int y=Y_MAX-(radius*2);
int x=X_MAX;
if(y<=radius) textDir = true;
else if(y>=(Y_MAX-radius)) textDir = false;
else if(x-24<=0) textRight = true;
if(textDir) y++;
else y--;
if(textRight) x++;
else x--;
toolbox.drawCircle(x, y, radius);
delay(100);
disp.clear();
* Copy a character glyph from the myfont data structure to
* display memory, with its upper left at the given coordinate
* This is unoptimized and simply uses setPixel() to draw each dot.
void drawChar(uint8_t x, uint8_t y, char c)
uint8_t dots;
if (c >= 'A' && c <= 'Z' ||
(c >= 'a' && c <= 'z') ) {
c &= 0x1F; // A-Z maps to 1-26
else if (c >= '0' && c <= '9') {
c = (c - '0') + 27;
else if (c == ' ') {
c = 0; // space
for (char col=0; col< 5; col++) {
dots = pgm_read_byte_near(&myfont[c][col]);
for (char row=0; row < 7; row++) {
if (dots & (64>>row)) // only 7 rows.
toolbox.setPixel(x+col, y+row, 1);
toolbox.setPixel(x+col, y+row, 0);
// Write out an entire string (Null terminated)
void drawString(uint8_t x, uint8_t y, char* c)
for(char i=0; i< strlen(c); i++)
drawChar(x, y, c[i]);
x+=6; // Width of each glyph
