I'm working on a laser spirograph and so I need to drive 3 12V DC fans and control the speed using PWM. I'm using a TIP120 to drive each fan and have a diode connected in parallel with each fan. Everything works fine if I only have one fan on at a time but once I try to turn on another fan it wont turn on until I turn the other ones off, so only one fan can be on at a time. The fans draw 0.16A at 12V each and I'm powering them with an AC adapter that can give .5A at 12V. I'm pretty sure my AC adapter should be able to supply enough power to all fans at once so I can't figure out why I cant have more than one on at a time. Here is the arduino code I'm using:
int firstByte;
int numericSerialNumber;
int pinA = 10;
int pinB = 9;
int pinC = 11;
int dataValueA = 0;
int dataValueB = 0;
int dataValueC = 0;
void readIn()
if (Serial.available() > 0)
firstByte = Serial.read();
if (firstByte == 'a' && Serial.available() == 3)
dataValueA = Serial.parseInt();
Serial.println("a");
if (firstByte == 'b' && Serial.available() ==3)
dataValueB = Serial.parseInt();
Serial.println("b");
if (firstByte == 'c' && Serial.available() ==3)
dataValueC = Serial.parseInt();
Serial.println("c");
if (firstByte == 'o' && Serial.available() == 0)
dataValueA = 0;
dataValueB = 0;
dataValueC = 0;
readIn();
analogWrite(pinA, dataValueA);
analogWrite(pinB, dataValueB);
analogWrite(pinC, dataValueC);
The incoming serial data is formatted as "a120", this sets pinA to 120 using analogWrite().
Any ideas/suggestions?
