Problems with 3.5" TFT Display ILI9488
Hi, I have a problem with the tft display ER-TFTM035-6 from buydisplay.com (link: https://www.buydisplay.com/default/lcd-3-5-inch-320x480-tft-display-module-optl-touch-screen-w-breakout-board , Datasheet: https://www.buydisplay.com/download/manual/ER-TFTM035-6_Datasheet.pdf ).
The display has an ILI9488 controller. I have tried several libraries ( GitHub - prenticedavid/ILI9488: Arduino Library for the ILI9488 TFT controller for 4 wire SPI, GitHub - giacu92/ILI9488_DMA: Arduino Library for the ILI9488 TFT controller for 4 wire SPI . Enanched speed over Arduino DUE using simil DMA ) and different Arduino boards (uno, mega, due) but my problem is still that the display is striped. I think the problem is with the libraries because when I press the reset button it is shown correctly for a few seconds.
Did any of you have similar problems or do any of you know what I did wrong?
Any help would be welcome.
tft-error.mpg (1.73 MB)
Looks like a bad connection.
I'm using a similar display connected to NodeMCU and the TFT_eSPI library, which is specifically for that processor. I've seen such striped image while experimenting and not all wires were that great.
