Hi! I have a pair of transmitter-receiver modules that communicate on 433MHz. I've written Arduino sketch for sending data from Arduino Uno to Arduino Pro Mini. While everything works fine, radio modules don't seem to communicate. I think that transmitter isn't transmitting because when I set it to send data every 0 seconds, LED blinks fast even though I've set baud rate to 10.
Here is code for transmitter:
#include <Wire.h>
#include <dht.h>
#include <Adafruit_BMP085.h>
#include <RTClib.h>
#include <WeatherCalculations.h>
#include <VirtualWire.h>
const byte DHTpin = 9;
const byte transmitPin = 10;
const float altitude = 222.0;
dht DHT;
Adafruit_BMP085 BMP;
RTC_DS1307 RTC;
Weather weather;
unsigned long lastTimeSensors = 2000UL;
unsigned long lastTimeTransmitter = 2000UL;
boolean correct = false;
boolean ledState = false;
struct packet {
float dewPoint, temperature, seaLevelPressure, airPressure, humidity;
byte hour, minute, second, day, month;
unsigned int year;
boolean clockTicking;
typedef struct packet Packet;
Packet data;
while (!BMP.begin() || !RTC.begin()) {}
vw_set_tx_pin(transmitPin);
vw_setup(500); // Bits per sec
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, LOW);
readSensorsAndTime();
sendData();
void readSensorsAndTime() {
if (millis() - lastTimeSensors >= 2000) {
do {
correct = DHT.read22(DHTpin);
data.humidity = DHT.humidity;
lastTimeSensors = millis();
} while (correct || data.humidity > 100.0);
data.temperature = BMP.readTemperature();
data.airPressure = BMP.readPressure() / 100.0;
data.seaLevelPressure = weather.getSeaLevelPressure(altitude, data.airPressure);
data.dewPoint = weather.getDewPoint(data.temperature, data.humidity);
data.clockTicking = RTC.isrunning();
DateTime now = RTC.now();
data.day = now.day();
data.month = now.month();
data.year = now.year();
data.hour = now.hour();
data.minute = now.minute();
data.second = now.second();
void sendData() {
if (millis() - lastTimeTransmitter >= 2000) {
vw_send((byte *)&data, sizeof(data));
vw_wait_tx(); // Wait until the whole message is gone
ledState = !ledState;
digitalWrite(LED_BUILTIN, ledState);
lastTimeTransmitter = millis();
And for the receiver:
#include <Wire.h>
const byte receivePin = 10;
unsigned long lastTimeLCD = 4000UL;
byte page = 1;
struct packet {
unsigned int year;
Packet data;
LiquidCrystal_I2C LCD(0x3F, 16, 2);
byte degree[8] = {
B00110,
B01001,
B01001,
B00110,
B00000,
B00000,
B00000,
B00000,
LCD.begin();
LCD.clear();
LCD.createChar(0, degree);
// Initialise the IO and ISR
vw_set_rx_pin(receivePin);
vw_rx_start(); // Start the receiver PLL running
receiveData();
writeOnLCD();
Serial.println(data.temperature);
void receiveData() {
byte buffer[sizeof(data)];
byte bufferLength = sizeof(data);
if (vw_have_message()) // Is there a packet for us?
vw_get_message(buffer, &bufferLength);
vw_wait_rx();
memcpy(&data, &buffer, bufferLength);
void writeOnLCD() {
if (!data.clockTicking) {
LCD.print(F("RTC not ticking!"));
if (millis() - lastTimeLCD >= 4000) {
LCD.clear();
LCD.setCursor(0, 0);
switch (page) {
case 1:
LCD.print(F("Temp: "));
LCD.print(data.temperature);
LCD.write(0);
LCD.print(F("C"));
LCD.setCursor(0, 1);
LCD.print(F("Hum: "));
LCD.print(data.humidity);
LCD.print(F("%"));
page = 2;
case 2:
LCD.print(F("Pr: "));
LCD.print(data.airPressure);
LCD.print(F("hPa"));
LCD.print(F("Dew pt: "));
LCD.print(data.dewPoint);
LCD.write(0);
LCD.print(F("C"));
page = 3;
case 3:
LCD.print(F("Pressure on sea:"));
LCD.print(data.seaLevelPressure);
page = 4;
case 4:
LCD.print(data.day);
LCD.print(F("."));
LCD.print(data.month);
LCD.print(F("."));
LCD.print(data.year);
LCD.print(F("."));
LCD.print(data.hour);
LCD.print(F(":"));
LCD.print(data.minute);
page = 1;
lastTimeLCD = millis();
Weather_Transmitter.ino (1.85 KB)
Weather_Receiver.ino (2.55 KB)
