I’m using an arduino to power two 4794 LED drivers, so I can display digits on my two 7 segment LEDs. Unfortunately, it isn’t working properly.
I can display any number, 00-99, but everytime a 1, 4, or 9 shows up on the display on the right a segment is lit up that shouldn’t be.
I’ve checked everything and it seems to be fine. What’s wrong!!?
Here’s the datasheet for the 4794s:
http://www.nxp.com/acrobat_download/datasheets/HEF4794B_3.pdf
And here’s my code:
int data = 9;
int strob = 8;
int clock = 10;
int oe = 11;
int count = 0;
long dato = 0;
int velocity = 00;
long binaryLED = 0;
pinMode(data, OUTPUT);
pinMode(clock, OUTPUT);
pinMode(strob, OUTPUT);
pinMode(oe, OUTPUT);
convert(velocity);
segmentWrite();
velocity++;
if(velocity==100){velocity=0;}
void segmentWrite(){
dato = binaryLED;
for (count = 0; count < 16; count++) {
digitalWrite(data, dato & 01);
dato>>=1;
if (count == 15){
digitalWrite(oe, LOW);
digitalWrite(strob, HIGH);
PulseClock();
digitalWrite(oe, HIGH);
delayMicroseconds(20);
digitalWrite(strob, LOW);
delay(100);
serialWrite(10);
serialWrite(13);
delay(100); // waits for a moment
void PulseClock(void) {
digitalWrite(clock, LOW);
digitalWrite(clock, HIGH);
delayMicroseconds(50);
int convert(int number){
int i = 0;
int numberl = 0;
int numberr = 0;
while(10*i<=number){
i++;
numberl = i - 1;
numberr = number - (10 * numberl);
binaryLED = 0;
if(numberl==0){
binaryLED = 32256;
}else if(numberl==1){
binaryLED = 4608;
}else if(numberl==2){
binaryLED = 48128;
}else if(numberl==3){
binaryLED = 46592;
}else if(numberl==4){
binaryLED = 53760;
}else if(numberl==5){
binaryLED = 58880;
}else if(numberl==6){
binaryLED = 60928;
}else if(numberl==7){
binaryLED = 12800;
}else if(numberl==8){
binaryLED = 65024;
}else if(numberl==9){
binaryLED = 61952;
if(numberr==0){
binaryLED = binaryLED + 126;
}else if(numberr==1){
binaryLED = binaryLED + 18;
}else if(numberr==2){
binaryLED = binaryLED + 188;
}else if(numberr==3){
binaryLED = binaryLED + 182;
}else if(numberr==4){
binaryLED = binaryLED + 210;
}else if(numberr==5){
binaryLED = binaryLED + 230;
}else if(numberr==6){
binaryLED = binaryLED + 238;
}else if(numberr==7){
binaryLED = binaryLED + 50;
}else if(numberr==8){
binaryLED = binaryLED + 254;
}else if(numberr==9){
binaryLED = binaryLED + 242;
