So I have a problem getting a MOSFET relay to work right. I'm using an Omron G3VM-21AR in the following configuration:
SIG, DIN, and CLK go to an Arduino which is powered separately. GND is common on both sides. The battery is a Li-Ion there to provide power to the LED string only.
When I keep SIG LOW, the LED string is off, and when I set it HIGH the string turns on. The idea here is that on the Arduino side, it could already be running, therefore sending data to the string. The relay is simply there to cut raw power to the string.
The problem I have is when I turn the relay on, the LED string comes on however the data being displayed is corrupted. If I disconnect the common ground between the string and the Arduino and reconnect it, then the string displays the incoming data as expected. But if I power cycle the relay again, everything goes to hell in a hand basket.
So, what's going on here and how can I fix it? I'm sure it's something I'm doing wrong but I can't figure out what.
Remove the ground from pin 4 on the LED string. Ground pin 1 on the LED string instead.
The way the circuit is drawn, the positive side of the Li-Ion battery is effectively grounded through the relay. The LED string thinks that its pin 1 is ground, but it's actually below ground level the way it's wired. That is probably messing with how the data signals get interpreted.
Doesn't work. The string turns on and off just like before, but now it doesn't show the proper data at all. Even if I remove and reconnect the common ground between the LED string and the Arduino.
If I remove the relay from the equation and just connect the wires that are going to pins 3 and 4 on the relay, the LED string works as expected. With the relay back in the circuit, the string just displays random colors.
I just noticed something else though, and may shed some light here. With the relay in place, the voltage difference at the LED string is much lower than the actual battery voltage. At the battery I can measure 4.1V (it's fully charged) and yet at the LED string, I measure 3.2V. That's a significant voltage loss ... Any ideas as to why?
And actually, the datasheet shows pins 2 and 3 on the relay to be grounded (pin 2 has a series resistor of 220 Ohm). So I reversed the battery so I can get a ground on pin 3, and reversed the connections on the LED string accordingly. The relay is turning things on and off as I send either a HIGH or LOW signal to it. So at least I know that works. What I can't explain is a) why the significant voltage drop, and b) why does the data get corrupted.
Now, it is entirely possible that it's due to the voltage drop. Even if the string's drivers work down to 2.5V (though the LEDs themselves only go as low as 2.8V).
I think you are getting parasitic powering of the LEDs. I have an LED string that glows dimly even when the power is off. Naturally I quickly disconnected the data lines as well.
If the power is off you should also have the data lines LOW.
That makes absolutely no difference. If I power the LEDs first, then the Arduino (therefore the data lines), it's corrupted.
If I have the Arduino powered, but no data being send, power the LEDs, then start sending data, it's corrupted.
If I power the Arduino and LEDs, then start sending data, it's corrupted.
Anything where the relay is in the circuit, it gets corrupted.
As soon as the relay is taken out of the circuit, I can do whatever I want as far as what gets powered first or when data gets sent, it always works.
And I still can't figure out why I'm getting such a drastic voltage drop across the relay.
Hi, I think you may have a problem with supply and filtering, you mentioned that the supply to the array with the mosfet relay was down to 3.2v.
These arrays have micrcontrollers built in them, probably running at 3.3V. If the main supply drops to 3.2V then the regulation will not be available to keep the microcontroller stable.
To fix this either use a small mechanical relay, or parallel up the output of three or more of these mosfet relays units to drop the switching resistance.
To check, measure the voltage across pins 3 and 4, AT THE opto mosfet relay and see if you are loosing the 1v there and not your wiring or too small width tracks to the opto mosfet relay.
I haven’t worked with MOSFET relays like that, from the datasheet I assume pins 3 and 4 would be interchangeable, but I might also try swapping them around.
TomGeorge:
Tom
No. This is a custom made strip. Just LEDs and drivers. The drivers are capable of running on 2.5V and it runs fine without the relay.
Yes, you can flip pins 3 and 4, just not 1 and 2. Though the datasheet also shows pin 3 being grounded, which would seem to indicate the MOSFET being on the low side. So I did try both, exactly like your schematic. In one case, pin 3 can get grounded, on the high side you don't ground it. Neither fixed the problem.
So my next step is trying to push the MOSFET with a higher current. Right now it's getting about 16mA, which is more than it's minimum of 10mA. But I'm going to push that to 20-25mA and see what happens. Its max is 30mA so I should be fine with 25 even.
However, that will have to wait till this evening because I left the unit running overnight (without the relay) so I can drain the battery and get a low voltage measurement base point for the voltage indicator being built-in the code.
Alternatively, can anyone suggest a different setup, with maybe different parts? I don’t have to use this specific opto MOSFET. I just need to be able to switch at least 2.5A from a Li+ battery (4.1V - 3.0V). I picked this one because I had one handy, it can switch up to 3A and it’s small - size is a requirement here.
How about just a MOSFET? Since you’re tying the grounds together on the two sides of the opto device, I assume isolation really isn’t necessary. The MOSFET part in the schematic will switch 5-6 amps, has RDS(ON) of 27m? @ VGS = 2.5V, and is in an SOT-23 package.
