Hi all,
(Im still learning)
On my way to something bigger Ive been looking around and found this pice of code http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1244372691
It is ment for 3-phase motors but I liked the way it had a dead spot in the middle of the pot and whent forward and backward.
To cut a long story short i hooked up 3 LEDs to the digital pins to see it work, then i got thinking what if i use analogOut and make two LEDs dim. . .
This is where Iv hit a snag, the 'forward' else if statment (> 542) works perfect but in the if > 482 statment it just makes the LED blink randomly.
I fixed it a little by putting in a delay, but its still there if you look hard, plus I would rather no use a delay i can...
Here is my code ( sorry its not all commented yet...) (the thrid LED is just the to show it is going 'forward')
int xPin = 2; //Define Pot One
int dir = 9; //Define Output Pins
int fwd = 11;
int rev = 10;
int val = 0; //Define Variable
pinMode(dir, OUTPUT); //Pin Mode
pinMode(fwd, OUTPUT);
pinMode(rev, OUTPUT);
{digitalWrite(13, LOW);}
val = analogRead(xPin);
if (val < 482) //this part dosent work quite right
digitalWrite(dir, LOW);
val = map(val, 0, 482, 255, 0);
analogWrite(rev, val);
delay(100);
else if (val > 542) //this part works great
val = map(val, 543, 1023, 0, 255);
analogWrite(fwd, val);
delay(100);
else // this part just does what it looks like
analogWrite(fwd, 0);
analogWrite(rev, 0);
{digitalWrite(13, HIGH);} //When we do nothing turn the LED on Pin13 ON
If anyone could help shead some light on this that would be great
I think the problem here is that you are updating the LEDs so often that you are getting a strobe effect between the degree of updating and the PWM frequency. This is helped by adding the delay.
I think there is a mix up between forward reverse and direction, you shouldn't need all three.
Even with a delay time of 1000ms it will still blink
Try a bit of debug and use the print statement to see what values you are reading and what values you are writing. That will give you a clue as to what is going on.
[edit]What still blinks? The Pin 13 LED or you motor LED?[/edit]
Ok,
So I did what you said and added some debuging and looking serial data coming back from the arduino everything looks like it should be working fine,
ie.
The potPin read's it full range 0 to 1023
In the < 482 section, the pot goes from 0 to 481 and anologPin 10 goes from 0 to 255 Like it should BUT the LED fill Blink randomly, it will flicker slightly too when the arduino is sending serial data. . .
And the > 542 section works perfectly and always has (it doesnt flicker when sending serial data either). . . .
I have changer some pins around, this is what the code looks like now
int xPin = 0; //Define Pot One
int dir = 8; //Define Output Pins
int fwd = 9;
int rev = 10;
Serial.begin(57600); //Turn on the Serial Port at 57600 bps
Serial.print("intval, ");
Serial.println(analogRead(0));
val = map(val, 1, 482, 255, 0);
Serial.print("revval, ");
Serial.println(val);
delay(100);
Serial.print("fwdval, ");
delay(100);
I think you have the if .. then ... else .. structure wrong. Try this:-
int fwd = 9;
int rev = 10;
delay(100);
delay(100);
if (val >= 482 && val <= 542) { // this part just does what it looks like
digitalWrite(13, HIGH); //When we do nothing turn the LED on Pin13 ON
