Problems with analog input reading with MKR1000 and a 9 V Battery
Hi to everyone !
I’m writing this topic to have an help about my project with an Arduino MKR 1000 powered by a 9 Volt Battery.
I need to read the value of the battery voltage to calculate the percentage of the charge.
I will attach the scheme.
I use a voltage divider to get 1/3 voltage of the battery on A0 and then i convert the value obtained with analogRead(A0) to a float and calculate the full voltage.
Here s the code :
#define PIN_BATTERY A0
float batteryVolt;
  batteryVolt = analogRead(PIN_BATTERY);
  Serial.println("Vout");
  batteryVolt = (batteryVolt * (3.3 / 1023.0));
  Serial.println(batteryVolt);
  Serial.println("Vin");
  batteryVolt = (batteryVolt*3.0);
The problem is that the value read from the Arduino is a lot higher than the value read by a tester, theese are the values :
Arduino Values
Vin = 7.97 battery V
Vout = 2.66 1/3 battery V
Tester Values
Vin = 7.80 battery V
Vout = 2.59 1/3 battery V
If i read the A0 without a pin it float around 1.31 V.
I dont know if this is normal and how can i fix it.
Also using more bits to read the analog value the value is remain the same.
It s not a lot of difference but for me is important.
You are within a very few %'s
What about the components you are using; Multimeter , resistors, the reference voltage, internal ADC .. are they all perfect?
Accept your numbers.. calibrate if the numbers are far off.
