Hi, First of all Im really new in this, pls bear with me.
I want to sense 3 variables and send it to a phone. Problem is when I try to read those 3 sensors, now im trying to join 2 of those, one is the pulsesensor (pulsesensor.com) that have his own code, the other is the lm35 temperature sensor. I probed the codes separated and work fine, problem is when i try to join. the temperature becomes crazy, i need help with this, I'll put the individual codes and next the joined codes. I hope you can help me pls. I repeat, Im really new.
pulsesensor code
// VARIABLES
int pulsePin = 0; // Pulse Sensor purple wire connected to analog pin 0
int blinkPin = 13; // pin to blink led at each beat
int fadePin = 5; // pin to do fancy classy fading blink at each beat
int fadeRate = 0; // used to fade LED on with PWM on fadePin
float temp;
int tempPin = 1;
// these variables are volatile because they are used during the interrupt service routine!
volatile int BPM; // used to hold the pulse rate
volatile int Signal; // holds the incoming raw data
volatile int IBI = 600; // holds the time between beats, must be seeded!
volatile boolean Pulse = false; // true when pulse wave is high, false when it's low
volatile boolean QS = false; // becomes true when Arduoino finds a beat.
void setup(){
pinMode(blinkPin,OUTPUT); // pin that will blink to your heartbeat!
pinMode(fadePin,OUTPUT); // pin that will fade to your heartbeat!
Serial.begin(115200); // we agree to talk fast!
interruptSetup(); // sets up to read Pulse Sensor signal every 2mS
// UN-COMMENT THE NEXT LINE IF YOU ARE POWERING The Pulse Sensor AT LOW VOLTAGE,
// AND APPLY THAT VOLTAGE TO THE A-REF PIN
// analogReference(EXTERNAL);
void loop(){
temp = analogRead(tempPin);
sendDataToProcessing('S', Signal); // send Processing the raw Pulse Sensor data
if (QS == true){ // Quantified Self flag is true when arduino finds a heartbeat
fadeRate = 255; // Set 'fadeRate' Variable to 255 to fade LED with pulse
sendDataToProcessing('B',BPM); // send heart rate with a 'B' prefix
sendDataToProcessing('Q',IBI); // send time between beats with a 'Q' prefix
QS = false; // reset the Quantified Self flag for next time
ledFadeToBeat();
delay(20); // take a break
void ledFadeToBeat(){
fadeRate -= 15; // set LED fade value
fadeRate = constrain(fadeRate,0,255); // keep LED fade value from going into negative numbers!
analogWrite(fadePin,fadeRate); // fade LED
void sendDataToProcessing(char symbol, int data ){
Serial.print(symbol); // symbol prefix tells Processing what type of data is coming
Serial.println(data); // the data to send culminating in a carriage return
now the lm35 code
float temp;
int tempPin = 0;
temp = temp * 0.48828125;
Serial.print("TEMPRATURE = ");
Serial.print(temp);
Serial.print("*C");
Finally what I made
// VARIABLES
float temp;
int tempPin = 1;
void setup(){
void loop(){
sendDataTemp('T',temp);
ledFadeToBeat();
void sendDataTemp(char symbol, float data ){
The problem is when I use the last code it show temperature but is not stable, for instance, the code for lm35 shows 22.5, 22.5, 22.4, 22.6, but the other shows like this: 22.5, 18.1, 31.0 etc, is always changing.
Thank you...
