Problems with AND function.
First of all… i’m just started programming, so please be kind :slight_smile:
I have made this code to control a series of 5 lamps in different patterns. An analog potmeter choose between the different codes.
I succeeded with 3 different patterns with the lines:
if (analogValue <200)
else if (analogValue >800)
But if i want 4 different patterns i need to use AND command, but i can’t make it work.
Fx:
else if(analogValue(>450)AND(<600))
Here is the full code:
Thanks
/Rasmus
int potPin = 2;
int val = 0;
const int led1 = 6;
const int led2 = 2;
const int led3 = 3;
const int led4 = 4;
const int led5 = 5;
const int analogPin = A0;    // pin that the sensor is attached to
const int threshold = 400;   // an arbitrary threshold level that's in the range of the analog input
  pinMode(led1, OUTPUT);
  pinMode(led2, OUTPUT);
  pinMode(led3, OUTPUT);
  pinMode(led4, OUTPUT);
  pinMode(led5, OUTPUT);
  int analogValue = analogRead(analogPin);
  if (analogValue < 200)
  val = analogRead(potPin);
  digitalWrite(led1, HIGH);
  digitalWrite(led2, HIGH);
  digitalWrite(led3, HIGH);
  digitalWrite(led4, HIGH);
  digitalWrite(led5, LOW);
  delay(val);
  digitalWrite(led1, LOW);
  digitalWrite(led5, HIGH);
  delay(val);
  digitalWrite(led2, LOW);
  delay(val);
  digitalWrite(led3, LOW);
  delay(val);
  digitalWrite(led4, LOW);
  delay(val);
  delay(val);
  delay(val);
  delay(val);
  delay(val);
  delay(val);
  delay(val);
  delay(val);
  delay(val);
  delay(val);
  delay(val);
  delay(val);
  delay(val);
  delay(val);
  delay(val);
  digitalWrite(led5, HIGH );
  delay(val);
else if (analogValue > 450 && analogValue < 600)
So simple.... thanks! ::)
Bookmark the Arduino Reference Page.
There's also the Libraries Page and a few others you might want to bring up in a browser tab to refer to when reading or writing code in the IDE.
Gateway to Foundations, Library, Examples, etc.
