Problems with Arduino and CTS 288 Encoders
Hello! New guy in this forum.
I’m asking for some advice (or help) with an Encoder doesn worling correctly.
I have a code for a 32 button Joystick, that is working really well with the generic EC11 encoders, wich have 20ppr.
Here’s the code:
#include <Keypad.h>
#include <Joystick.h>
#define ENABLE_PULLUPS
#define NUMROTARIES 4
#define NUMBUTTONS 12
#define NUMROWS 4
#define NUMCOLS 3
byte buttons[NUMROWS][NUMCOLS] = {
  {0,1,2},
  {3,4,5},
  {6,7,8},
  {9,10,11},
struct rotariesdef {
  byte pin1;
  byte pin2;
  int ccwchar;
  int cwchar;
  volatile unsigned char state;
rotariesdef rotaries[NUMROTARIES] {
  {0,1,24,25,0},
  {2,3,26,27,0},
  {4,5,28,29,0},
  {6,7,30,31,0},
#define DIR_CCW 0x10
#define DIR_CW 0x20
#define R_START 0x0
#ifdef HALF_STEP
#define R_CCW_BEGIN 0x1
#define R_CW_BEGIN 0x2
#define R_START_M 0x3
#define R_CW_BEGIN_M 0x4
#define R_CCW_BEGIN_M 0x5
const unsigned char ttable[6][4] = {
  // R_START (00)
  {R_START_M,            R_CW_BEGIN,     R_CCW_BEGIN,  R_START},
  // R_CCW_BEGIN
  {R_START_M | DIR_CCW, R_START,        R_CCW_BEGIN,  R_START},
  // R_CW_BEGIN
  {R_START_M | DIR_CW,  R_CW_BEGIN,     R_START,      R_START},
  // R_START_M (11)
  {R_START_M,            R_CCW_BEGIN_M,  R_CW_BEGIN_M, R_START},
  // R_CW_BEGIN_M
  {R_START_M,            R_START_M,      R_CW_BEGIN_M, R_START | DIR_CW},
  // R_CCW_BEGIN_M
  {R_START_M,            R_CCW_BEGIN_M,  R_START_M,    R_START | DIR_CCW},
#else
#define R_CW_FINAL 0x1
#define R_CW_NEXT 0x3
#define R_CCW_BEGIN 0x4
#define R_CCW_FINAL 0x5
#define R_CCW_NEXT 0x6
const unsigned char ttable[7][4] = {
  // R_START
  {R_START,    R_CW_BEGIN,  R_CCW_BEGIN, R_START},
  // R_CW_FINAL
  {R_CW_NEXT,  R_START,     R_CW_FINAL,  R_START | DIR_CW},
  // R_CW_BEGIN
  {R_CW_NEXT,  R_CW_BEGIN,  R_START,     R_START},
  // R_CW_NEXT
  {R_CW_NEXT,  R_CW_BEGIN,  R_CW_FINAL,  R_START},
  // R_CCW_BEGIN
  {R_CCW_NEXT, R_START,     R_CCW_BEGIN, R_START},
  // R_CCW_FINAL
  {R_CCW_NEXT, R_CCW_FINAL, R_START,     R_START | DIR_CCW},
  // R_CCW_NEXT
  {R_CCW_NEXT, R_CCW_FINAL, R_CCW_BEGIN, R_START},
#endif
byte rowPins[NUMROWS] = {21,20,19,18};
byte colPins[NUMCOLS] = {15,14,16};
Keypad buttbx = Keypad( makeKeymap(buttons), rowPins, colPins, NUMROWS, NUMCOLS);
Joystick_ Joystick(JOYSTICK_DEFAULT_REPORT_ID,
  JOYSTICK_TYPE_JOYSTICK, 32, 0,
  false, false, false, false, false, false,
  false, false, false, false, false);
  Joystick.begin();
  rotary_init();}
  CheckAllEncoders();
  CheckAllButtons();
void CheckAllButtons(void) {
      if (buttbx.getKeys())
       for (int i=0; i<LIST_MAX; i++)
           if ( buttbx.key[i].stateChanged )
            switch (buttbx.key[i].kstate) {
                    case PRESSED:
                    case HOLD:
                              Joystick.setButton(buttbx.key[i].kchar, 1);
                    case RELEASED:
                    case IDLE:
                              Joystick.setButton(buttbx.key[i].kchar, 0);
void rotary_init() {
  for (int i=0;i<NUMROTARIES;i++) {
    pinMode(rotaries[i].pin1, INPUT);
    pinMode(rotaries[i].pin2, INPUT);
    #ifdef ENABLE_PULLUPS
      digitalWrite(rotaries[i].pin1, HIGH);
      digitalWrite(rotaries[i].pin2, HIGH);
    #endif
unsigned char rotary_process(int _i) {
   unsigned char pinstate = (digitalRead(rotaries[_i].pin2) << 1) | digitalRead(rotaries[_i].pin1);
  rotaries[_i].state = ttable[rotaries[_i].state & 0xf][pinstate];
  return (rotaries[_i].state & 0x30);
void CheckAllEncoders(void) {
    unsigned char result = rotary_process(i);
    if (result == DIR_CCW) {
      Joystick.setButton(rotaries[i].ccwchar, 1); delay(50); Joystick.setButton(rotaries[i].ccwchar, 0);
    if (result == DIR_CW) {
      Joystick.setButton(rotaries[i].cwchar, 1); delay(50); Joystick.setButton(rotaries[i].cwchar, 0);
The problem is: I connect the CTS 288 encoder to the correct pins, but the “Joystick” read an input every 4 pulses, or “clicks” from the encoder. The encoder has 16 detents, and one pulse per detent, but the input is detected after 4 detents has passed.
Is there a variable that i need to change in order to work properly?? (if so, i’m not seeing it).
Any help will be very apreciated!
David.
PD: Sorry if my english is not the better.
Can we have some links to those encoder components for convenience? Did you make any pin configuration changes in the new sketch? Can you explain the differences between an EC11 and a CTS 288?
Dear,
i have the same problem
running a similar code
data sheet attached
i also added a picture showing the selected CTS
Many Thanks in advance
Peter
288-1138422 (2).pdf (192 KB)
that is the code i am running - downloaded out of arduino
RotaryEncoder by Matthias Hertel
then under examples RotaryEncoder - SimplePollRotator
// SimplePollRotator.ino - Example for the RotaryEncoder library.
// This class is implemented for use with the Arduino environment.
// Copyright (c) by Matthias Hertel, http://www.mathertel.de
// This work is licensed under a BSD style license. See http://www.mathertel.de/License.aspx
// More information on: http://www.mathertel.de/Arduino
// 18.01.2014 created by Matthias Hertel
// This example checks the state of the rotary encoder in the loop() function.
// The current position is printed on output when changed.
// Hardware setup:
// Attach a rotary encoder with output pins to A2 and A3.
// The common contact should be attached to ground.
#include <RotaryEncoder.h>
// Setup a RoraryEncoder for pins A2 and A3:
RotaryEncoder encoder(A2, A3);
  Serial.begin(57600);
  Serial.println("SimplePollRotator example for the RotaryEncoder library.");
} // setup()
// Read the current position of the encoder and print out when changed.
  static int pos = 0;
  encoder.tick();
  int newPos = encoder.getPosition();
  if (pos != newPos) {
    Serial.print(newPos);
    pos = newPos;
  } // if
} // loop ()
// The End
// RotaryEncoder.h - Library for using rotary encoders.
// 16.06.2019 pin initialization using INPUT_PULLUP
#ifndef RotaryEncoder_h
#define RotaryEncoder_h
#include "Arduino.h"
#define LATCHSTATE 3
class RotaryEncoder
public:
  enum class Direction { NOROTATION = 0, CLOCKWISE = 1, COUNTERCLOCKWISE = -1};
  // ----- Constructor -----
  RotaryEncoder(int pin1, int pin2);
  // retrieve the current position
  long  getPosition();
  // simple retrieve of the direction the knob was rotated at. 0 = No rotation, 1 = Clockwise, -1 = Counter Clockwise
  Direction getDirection();
  // adjust the current position
  void setPosition(long newPosition);
  // call this function every some milliseconds or by using an interrupt for handling state changes of the rotary encoder.
  void tick(void);
  // Returns the time in milliseconds between the current observed
  unsigned long getMillisBetweenRotations() const;
private:
  int _pin1, _pin2; // Arduino pins used for the encoder.
  volatile int8_t _oldState;
  volatile long _position;         // Internal position (4 times _positionExt)
  volatile long _positionExt;      // External position
  volatile long _positionExtPrev;  // External position (used only for direction checking)
  unsigned long _positionExtTime;     // The time the last position change was detected.
  unsigned long _positionExtTimePrev; // The time the previous position change was detected.
#endif
// End
Thanks... Tom... :slight_smile:
jpg ok?
or do you like to see more details
screenshot of my arduino monitor
getting correct outputs - but only after every 4th click :slight_smile:
OPs circuit;
What is the full part number of your encoder?
Hi Tom,
had this in one of my first posts
added the screenshot again to see what is behind
288 T 2 32 R 13 1 A 2
Peter
Hi Tom,
did you find something?
on my circuit - did i share what you are looking for?
or did you request something else
Peter
