this is more of a bug report, but if I did anything wrong, feel free to point it out.(PLEASE)
I revisited the my Arduino IDE and stumbled across an error with the firmware(?) of the Arduino Zero, version 1.6.13.
I used Arduino IDE v.1.6.10 (Linux) and a freshly installed IDE v. 1.8.2 (Windows), and on both this error message pops up when trying to upload a sektch or burn the bootloader:
Arduino: 1.8.2 (Windows 10), Board: "Arduino/Genuino Zero (Programming Port)"
Build options changed, rebuilding all
Archiving built core (caching) in: C:\Users\TheBeast\AppData\Local\Temp\arduino_cache_216363\core\core_arduino_samd_arduino_zero_edbg_aba0f4eb37537bd009134604688a8b76.a
Sketch uses 11000 bytes (4%) of program storage space. Maximum is 262144 bytes.
java.io.IOException: Cannot run program "{runtime.tools.openocd-0.9.0-arduino5-static.path}/bin/openocd.exe": CreateProcess error=2, Das System kann die angegebene Datei nicht finden(translates to "The system could not find the specified file")
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1048)
at processing.app.helpers.ProcessUtils.exec(ProcessUtils.java:26)
at cc.arduino.packages.Uploader.executeUploadCommand(Uploader.java:129)
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:207)
at cc.arduino.UploaderUtils.upload(UploaderUtils.java:78)
at processing.app.SketchController.upload(SketchController.java:713)
at processing.app.SketchController.exportApplet(SketchController.java:686)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2135)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.io.IOException: CreateProcess error=2, Das System kann die angegebene Datei nicht finden(="The system could not find the specified file")
at java.lang.ProcessImpl.create(Native Method)
at java.lang.ProcessImpl.<init>(ProcessImpl.java:386)
at java.lang.ProcessImpl.start(ProcessImpl.java:137)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1029)
... 8 more
An error occurred while uploading the sketch
When using older versions(tried 1.6.9 & 1.6.10), everything works just fine.
Had the same issues. Reinstalling the 'boards' using Tools > Board:... > Boards manager sloved it for me. Make sure that you don't close the IDE before the installation finished!!!
This was caused by a bug in the Arduino SAMD Boards 1.6.13 release. I have submitted a pull request to get this fixed. You can see the necessary change here:
So you have two options:
Option 1 (fix the bug):
Open C:\Users\xxx\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.13\platform.txt in a text editor
TheBeast08:
I get the same problem with 1.6.9. I'm not sure how it could work unless you are using an older version of Arduino SAMD Boards.
FlorisVO:
That's strange. Are you sure you didn't revert to Arduino SAMD Boards 1.6.12 when you did that?
