Problems with Arduino Mega 2560 on Windows Vista-64
I am using a Arduino Mega 2560 Board connected to a Windows Vista-64 computer. Everything says it downloaded and installed correctly. When I connect the USB cable there is a Red LED that comes on. It is located just above the reset switch (Button). The L, TX & RX LED's do not light up or blink. When trying to upload the file "Blink", to test the system, I get. what appears to be a freeze in the upload process. A bright flash comes from the red L LED followed by a dim steady light from this LED. The green RX LED blinks about every 10 seconds. The upload never appears to become complete. Any Ideas?
Are there any messages in the IDE?
Enable the verbose upload option in preferences, and see if that tells you anything.
Binary sketch size: 1,632 bytes (of a 258,048 byte maximum)
C:\Users**\arduino-1.0.1-windows\arduino-1.0.1\hardware/tools/avr/bin/avrdude -CC:\Users**\arduino-1.0.1-windows\arduino-1.0.1\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\.\COM4 -b115200 -D -Uflash:w:C:\Users**~1\AppData\Local\Temp\build8774323326409129864.tmp\Blink.cpp.hex:i
avrdude: Version 5.11, compiled on Sep 2 2011 at 19:38:36
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is “C:\Users**\arduino-1.0.1-windows\arduino-1.0.1\hardware/tools/avr/etc/avrdude.conf”
Using Port : \.\COM4
Using Programmer : stk500v2
Overriding Baud Rate : 115200
avrdude: Send: . [1b] . [01] . [00] . [01] . [0e] . [01] . [14]
avrdude: Recv:
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: stk500v2_getsync(): timeout communicating with programmer
AVR Part : ATMEGA2560
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 4096 8 0 9000 9000 0x00 0x00
flash 65 10 256 0 yes 262144 256 1024 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500V2
Description : Atmel STK500 Version 2.x firmware
Programmer Model: Unknown
avrdude: Send: . [1b] . [01] . [00] . [02] . [0e] . [03] . [90] . [85]
Does the verbose printout tell you anything? I see it has timed out getting a message back. The question is why?
