Problems with ATMega328? (The one without the P?)
At least in Chile, I could only find the ATMega328, not the ATMega328P; there's an issue with the chip's signature.
I solved the issue by adding the extra chip in both the boards.txt
atmega328.name=Arduino Duemilanove w/ ATmega328 that has no P
atmega328.upload.protocol=arduino
atmega328.upload.maximum_size=30720
atmega328.upload.speed=57600
atmega328.bootloader.low_fuses=0xFF
atmega328.bootloader.high_fuses=0xDA
atmega328.bootloader.extended_fuses=0x05
atmega328.bootloader.path=arduino:atmega
atmega328.bootloader.file=ATmegaBOOT_168_atmega328.hex
atmega328.bootloader.unlock_bits=0x3F
atmega328.bootloader.lock_bits=0x0F
atmega328.build.mcu=atmega328
atmega328.build.f_cpu=16000000L
atmega328.build.core=arduino:arduino
and in avrdude.conf
# ATmega328
part
    id			= "m328";
    desc		= "ATMEGA328";
    has_debugwire	= yes;
    flash_instr		= 0xB6, 0x01, 0x11;
    eeprom_instr	= 0xBD, 0xF2, 0xBD, 0xE1, 0xBB, 0xCF, 0xB4, 0x00,
			  0xBE, 0x01, 0xB6, 0x01, 0xBC, 0x00, 0xBB, 0xBF,
			  0x99, 0xF9, 0xBB, 0xAF;
    stk500_devcode	= 0x86;
    # avr910_devcode	= 0x;
    signature		= 0x1e 0x95 0x14;
    pagel		= 0xd7;
    bs2			= 0xc2;
    chip_erase_delay	= 9000;
    pgm_enable = "1 0 1 0 1 1 0 0 0 1 0 1 0 0 1 1",
		 "x x x x x x x x x x x x x x x x";
    chip_erase = "1 0 1 0 1 1 0 0 1 0 0 x x x x x",
    timeout	= 200;
    stabdelay	= 100;
    cmdexedelay	= 25;
    synchloops	= 32;
    bytedelay	= 0;
    pollindex	= 3;
    pollvalue	= 0x53;
    predelay	= 1;
    postdelay	= 1;
    pollmethod	= 1;
    pp_controlstack =
	0x0E, 0x1E, 0x0F, 0x1F, 0x2E, 0x3E, 0x2F, 0x3F,
	0x4E, 0x5E, 0x4F, 0x5F, 0x6E, 0x7E, 0x6F, 0x7F,
	0x66, 0x76, 0x67, 0x77, 0x6A, 0x7A, 0x6B, 0x7B,
	0xBE, 0xFD, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00;
    hventerstabdelay	= 100;
    progmodedelay	= 0;
    latchcycles		= 5;
    togglevtg		= 1;
    poweroffdelay	= 15;
    resetdelayms	= 1;
    resetdelayus	= 0;
    hvleavestabdelay	= 15;
    resetdelay		= 15;
    chiperasepulsewidth	= 0;
    chiperasepolltimeout = 10;
    programfusepulsewidth = 0;
    programfusepolltimeout = 5;
    programlockpulsewidth = 0;
    programlockpolltimeout = 5;
    memory "eeprom"
	paged		= no;
	page_size	= 4;
	size		= 1024;
	min_write_delay = 3600;
	max_write_delay = 3600;
	readback_p1	= 0xff;
	readback_p2	= 0xff;
	read = " 1 0 1 0 0 0 0 0",
	       " 0 0 0 x x x a9 a8",
	       " a7 a6 a5 a4 a3 a2 a1 a0",
	       " o o o o o o o o";
	write = " 1 1 0 0 0 0 0 0",
		" i i i i i i i i";
	loadpage_lo = " 1 1 0 0 0 0 0 1",
		      " 0 0 0 0 0 0 0 0",
		      " 0 0 0 0 0 0 a1 a0",
		      " i i i i i i i i";
	writepage = " 1 1 0 0 0 0 1 0",
		    " 0 0 x x x x a9 a8",
		    " a7 a6 a5 a4 a3 a2 0 0",
		    " x x x x x x x x";
	mode		= 0x41;
	delay		= 20;
	blocksize	= 4;
	readsize	= 256;
    memory "flash"
	paged		= yes;
	size		= 32768;
	page_size	= 128;
	num_pages	= 256;
	min_write_delay = 4500;
	max_write_delay = 4500;
	readback_p1	= 0xff;
	readback_p2	= 0xff;
	read_lo = " 0 0 1 0 0 0 0 0",
		  " 0 0 a13 a12 a11 a10 a9 a8",
		  " o o o o o o o o";
	read_hi = " 0 0 1 0 1 0 0 0",
		  " o o o o o o o o";
	loadpage_lo = " 0 1 0 0 0 0 0 0",
		      " 0 0 0 x x x x x",
		      " x x a5 a4 a3 a2 a1 a0",
		      " i i i i i i i i";
	loadpage_hi = " 0 1 0 0 1 0 0 0",
		      " 0 0 0 x x x x x",
		      " i i i i i i i i";
	writepage = " 0 1 0 0 1 1 0 0",
		    " a7 a6 x x x x x x",
		    " x x x x x x x x";
	mode		= 0x41;
	delay		= 6;
	blocksize	= 128;
	readsize	= 256;
    memory "lfuse"
	size = 1;
	read = "0 1 0 1 0 0 0 0 0 0 0 0 0 0 0 0",
	       "x x x x x x x x o o o o o o o o";
	write = "1 0 1 0 1 1 0 0 1 0 1 0 0 0 0 0",
	      	"x x x x x x x x i i i i i i i i";
    memory "hfuse"
	size = 1;
	read = "0 1 0 1 1 0 0 0 0 0 0 0 1 0 0 0",
	write = "1 0 1 0 1 1 0 0 1 0 1 0 1 0 0 0",
    memory "efuse"
	size = 1;
	read = "0 1 0 1 0 0 0 0 0 0 0 0 1 0 0 0",
	       "x x x x x x x x x x x x x o o o";
	write = "1 0 1 0 1 1 0 0 1 0 1 0 0 1 0 0",
	      	"x x x x x x x x x x x x x i i i";
    memory "lock"
	size = 1;
	read = "0 1 0 1 1 0 0 0 0 0 0 0 0 0 0 0",
	       "x x x x x x x x x x o o o o o o";
	write = "1 0 1 0 1 1 0 0 1 1 1 x x x x x",
	      	"x x x x x x x x 1 1 i i i i i i";
    memory "calibration"
	size = 1;
	read = "0 0 1 1 1 0 0 0 0 0 0 x x x x x",
	       "0 0 0 0 0 0 0 0 o o o o o o o o";
    memory "signature"
	size = 3;
	read = "0 0 1 1 0 0 0 0 0 0 0 x x x x x",
	       "x x x x x x a1 a0 o o o o o o o o";
I thought it could be helpful to someone. :slight_smile:
Genial, hace menos de una semana un amigo me comentó que no había podido usar el atmega de olimex, debió ser esto.
Yes, that's exactly it; MCI ltda. (aka olimex.cl) only sells the power hungry version.
NiñoScript:
Nice. I added your board definition in the mod :smiley:
Could you add similar definitions for 1284 & 1284P?
I could try… but I don't think I can.
I don't really know what all of that means, I just knew that the ATMega328 is exactly the same as the ATMega328P but with a different signature. :drooling_face:
http://arduino.cc/forum/index.php/topic,118440.0.html :slight_smile: board is included now! thanks
Hello Experts,
I am in a similar situation, after being given ATMEGA 328-PU chips to works with. I am trying to follow these instructions, but cannot find the avrdude.conf file. I am using macintosh computer, which might put me at a disadvantage :frowning: Does anyone know where the avrdude.comf file is on a mac install of arduino?
Do a simple search. Easy to find in arduino path.
