Problems with Attiny85 and SX1278 module LoRa
Hello everyone!
I am trying to communicate the SX1278 LoRa 433MHz Ra-02 module with attiny85 in my project. But I'm getting the errors during compilation:
F:\Arduino\libraries\LoRa\src/LoRa.h:77:15: error: 'SPIClass' has not been declared
   void setSPI(SPIClass& spi);
F:\Arduino\libraries\LoRa\src/LoRa.h:101:3: error: 'SPIClass' does not name a type
   SPIClass* _spi;
I'm using AttinyCore (available at: GitHub - SpenceKonde/ATTinyCore: Arduino core for ATtiny 1634, 828, x313, x4, x41, x5, x61, x7 and x8), Arduino IDE in version 1.8.9 and my tests are based on the LoraReceiver example from the arduino-LoRa library (available at: GitHub - sandeepmistry/arduino-LoRa: An Arduino library for sending and receiving data using LoRa radios.), follow the example code snippet:
#include <SPI.h>
#include <LoRa.h>
int counter = 0;
  while (!Serial);
  Serial.println("LoRa Sender");
  if (!LoRa.begin(433E6)) {
    Serial.println("Starting LoRa failed!");
    while (1);
  Serial.print("Sending packet: ");
  Serial.println(counter);
  // send packet
  LoRa.beginPacket();
  LoRa.print("hello ");
  LoRa.print(counter);
  LoRa.endPacket();
  counter++;
  delay(5000);
Thanks any help!
What makes you think the LoRa library was intended to work on the AtTiny85?
It looks like the LoRa library you are usign is not compatible with the SPI library for the ATTiny.
Either raise the issue with the author of the LoRa library or try another one.
Okay, thanks, I'll continue testing other libraries.
The idea came from another related topic (link: Programming Attiny45 with Uno. Problems finding good information. - Microcontrollers - Arduino Forum), where it apparently worked successfully.
If anyone has a solution I will be very grateful.
Gustavo9786:
Maybe the LoRa library you are using has changed, as I suggested ask the author ........
