Hello!
I'm trying to work with serial bluetooth and wifi+mqtt, but I'm having problems:
#include "BluetoothSerial.h"
#include <WiFi.h>
#include <PubSubClient.h>
#include <WiFiClient.h>
#if !defined(CONFIG_BT_ENABLED) || !defined(CONFIG_BLUEDROID_ENABLED)
#error Bluetooth is not enabled! Please run `make menuconfig` to and enable it
#endif
BluetoothSerial SerialBT;
String msgB;
String usermqtt;
const char* mqtt_server = "XXX.XXX.XXX.123";
WiFiClient wifiClient;
PubSubClient client(wifiClient);
SerialBT.begin("ESP32test"); //Bluetooth device name
Serial.println("The device started, now you can pair it with bluetooth!");
if (WiFi.begin("SSID", "pass")) {
client.setServer(mqtt_server, 1883);
client.setBufferSize(30000);
client.setCallback(callback);
client.setKeepAlive(90);
usermqtt = "esp32/user/777";
verificaMqtt();
client.loop();
if (Serial.available()) {
SerialBT.write(Serial.read());
/*if (SerialBT.available()) {
Serial.write(SerialBT.read());
if (SerialBT.available() > 0) {
msgB = "";
while (SerialBT.available() > 0) {
char ch = SerialBT.read();
msgB += ch;
delay(5);
Serial.println("Mensagem:");
Serial.println(msgB);
Serial.println("Tamanho:");
Serial.println(msgB.length());
if (msgB == "page0") {
Serial.println("Enviando...");
sendMsg("page0ok");
else if (msgB == "page1") {
sendMsg("page1ok");
if (!SerialBT.hasClient()) {
Serial.println("NAO CONECTADO");
delay(20);
void sendMsg(String a)
uint8_t buf[a.length()];
memcpy(buf, a.c_str(), a.length());
SerialBT.write(buf, a.length());
void verificaMqtt()
if (!client.connected())
Serial.println(F("DESCONECTOU MQTT, CONECTANDO NOVAMENTE"));
connectMqtt();
void connectMqtt() {
if (client.connect(usermqtt.c_str(), "user", "pass1234")) {
//Serial.println(F("conectado!"));
String sub = "topic1/lyme3";
if (client.subscribe(sub.c_str())) {
Serial.println(F("Se inscreveu no tópico"));
Serial.println(sub);
Serial.print("falha, erro =");
Serial.print(client.state());
void callback(char* topic, unsigned char* message, unsigned int length) {
Serial.print("Mensagem chegou no topico: ");
Serial.print(topic);
Serial.print(". Mensagem: ");
String messageTemp;
for (int i = 0; i < length; i++) {
messageTemp += (char)message[i];
messageTemp = "";
When loading this sketch, the wifi, bluetooth and mqtt connections are made without error, but I don't receive anything from the topic I subscribe to. And after a while the mqtt connection starts to wobble, then it disconnects and connects again, then disconnects and so on. But in this same sketch, if I take the Bluetooth functionality out of the code, the mqtt works without any problem. The mqtt connection does not drop and I receive messages normally.
Can anyone help me?
