Hi!
I'm making a midi controller and got some problems. The multiplexed potentiometers that I'm using with multiplexers are working great, now I'm trying to connect 16 buttons through kind of the same code but with some edits. The hardware is ok I think, so if anyone could check my code for errors I would be happy! It's compiling but I'm pretty new to this so I probably have some errors anyway..
First of all I need to get the multiplexer working for the buttons. Right now with this shortened code I get no messages at all from the device. If I change the code a bit I can get some midi messages, but it's some kind of a loop that is not correct and the buttons doesn't change anything if I press them. So it's probably something more basic.
When the multiplexer is reading the buttons I will go further to send signals to corresponding leds. But that's for the next step.
I'm using a Teensy LC for this project.
All help is much appreciated!
Diagram/schematic for the hardware here!
// Teensy Monster V1
// teensymonster.cc
// Code v1.0
// last updated April, 2014
// license __ http://opensource.org/licenses/MIT
// Edit: Imbecillen 2018
// SETTINGS ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
//CHANNEL_____________________________________________
int channelNumber = 1; //each controller should have a unique channel number between 1 and 10
//DEBOUNCE BUTTONS___________________________________
//debounce is a measurement of the time in which a pushbutton is unresponsive after it is pressed
//this is important to prevent unwanted double clicks
uint32_t pbBounce = 150; //150 millisecond debounce duration - you may want to change this value depending on the mechanics of your pushbuttons
//MULTIPLEXER READING_________________________________
//CD4067BE - http://www.ti.com/lit/ds/symlink/cd4067b.pdf
//'1' for multiplexer I/O you want to send signal, else enter '0'
//MULTIPLEXER 5, DIGITAL FOR PUSHBUTTONS______________
int toReadDigitalMux5[16] = {
//IC pin number are written below
1, 1, 1, 1, //0-3
1, 1, 1, 1, //4-7
1, 1, 1, 1, //8-11
1, 1, 1, 1 //12-15
//PUSHBUTTON MODE______________________________________
//there are a few different modes in which you may wish for your pushbutton to behave
//'1' - standard mode, when pushbutton is engaged note is turned on, when pushbutton is released, note is turned off
//'2' - on mode, note is only turned on with each click
//'3' - off mode, note is only turned off with each click
//'4' - toggle mode, note is switched between on and off with each click
int pushbuttonMode[32] = {
//Pin number are written below
4, 4, 4, 4, //0-3
4, 4, 4, 4, //4-7
4, 4, 4, 4, //8-11
4, 4, 4, 4 //12-15 (NOTE: comma after last row/number for shift function to continue down under)
// VARIABLES AND FUNCTIONS ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
//MULTIPLEXER CONTROL SIGNAL____________________________
int s0 = 1; //control pin A
int s1 = 2; //control pin B
int s2 = 3; //control pin C
int s3 = 4; //control pin D
//MULTUPLEXER INHIBITOR PIN_____________________________
int INH_pin = 9;
//MULTIPLEXER NR 5 _____________________________________
//DIGITAL IN, SIGNAL PIN FOR BUTTONS
//(16 buttons in total)
int SIG_pin5 = 6; //digital mux read pin for muxButtons
//MULTIPLEXER NR 5, DIGITAL IN FOR PUSH BUTTONS_________
long timeHit[16]; //16*2 = 32 for shift button code
boolean buttonState[16]; //array with stored state: if the button was last turned on or off
boolean tempDigitalRead5 = 0;//array to hold previously read values
int controlPin5[] = {s0, s1, s2, s3}; //set contol pins in array
//control array
int muxChannel5[16][4] = {{0, 0, 0, 0}, {1, 0, 0, 0}, {0, 1, 0, 0}, {1, 1, 0, 0}, {0, 0, 1, 0},
{1, 0, 1, 0}, {0, 1, 1, 0}, {1, 1, 1, 0}, {0, 0, 0, 1}, {1, 0, 0, 1}, {0, 1, 0, 1}, {1, 1, 0, 1},
{0, 0, 1, 1}, {1, 0, 1, 1}, {0, 1, 1, 1}, {1, 1, 1, 1}};
//function to read mux
int readMux5(int channel5) {
//loop through the four control pins
for (int i = 0; i < 4; i ++) {
//turn on/off the appropriate control pins according to what channel we are trying to read
digitalWrite(controlPin5[i], muxChannel5[channel5][i]);
delay(20);
//read the value of the pin
int val = digitalRead(SIG_pin5);
//return the value
return val;
// SETUP ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
//AREF_______________________________________________
// Voltage reference for analog input, MUST BE BEFORE analogRead!
analogReference(EXTERNAL);
//MULTIPLEXER SETUP _________________________________
//set multiplexers reading pin
pinMode(SIG_pin5, INPUT_PULLUP);
//set inhibit pin to output and turn off
pinMode(INH_pin, OUTPUT);
digitalWrite(INH_pin, LOW);
//set our control pins to output
pinMode(s0, OUTPUT);
pinMode(s1, OUTPUT);
pinMode(s2, OUTPUT);
pinMode(s3, OUTPUT);
//turn all control pins off (for now)
digitalWrite(s0, LOW);
digitalWrite(s1, LOW);
digitalWrite(s2, LOW);
digitalWrite(s3, LOW);
} // SETUP END
// LOOP ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
//MULTIPLEXER 5
//DIGITAL IN FOR BUTTONS ________________________________
for (int i = 0; i < 16; i++) { //loop through 16 mux channels
if (toReadDigitalMux5[i] == 1) { //we read the choosen mux channel input
tempDigitalRead5 = readMux5(i);
if (pushbuttonMode[i] == 1 && tempDigitalRead5 != buttonState[i]) { //___NORMAL MODE (1)
delay(20); //just a delay for noise to ensure push button was actually hit
if (readMux5(i) == tempDigitalRead5) { //check if pushbutton is still the same
if (tempDigitalRead5 == LOW) { //button pressed, turn note on
midiSend('p', 1, i); //call note on/off function
} else { //button released
midiSend('p', 0, i);
buttonState[i] = tempDigitalRead5; //update the state (on or off)
} else { //___ALL OTHER MODES (2,3,4)
if (readMux5(i) == LOW && (millis() - timeHit[i]) > pbBounce) { //check bounce time
if (pushbuttonMode[i] == 2) { //mode 2 - only note on
} else if (pushbuttonMode[i] == 3) { //mode 3 - only note off
} else { //mode 4 - toggle
if (buttonState[i] == 1) { //on->off
buttonState[i] = 0;
} else { //off->on
buttonState[i] = 1;
timeHit[i] = millis();
} // LOOP END
// COMMUNICATION FUNCTIONS ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
// http://www.pjrc.com/teensy/td_midi.html
//FUNCTIONS TO SEND MIDI______________________________
void midiSend(char type, int val, int pin) {
switch (type) {
case 'p': //--------------- PUSHBUTTON
if (val == 1) {
usbMIDI.sendNoteOn(pin, 127, channelNumber); //!!!
usbMIDI.sendNoteOff(pin, 127, channelNumber); //!!!
