problems with cases
I am working on a project that uses cases to do things. It’s a dead bolt that uses RF key fob. It checks for unlock or lock button press and also checks if the lock is locked or not. I thin for some reason the lock state isn’t changing because I am only getting cases 2 and 4.
I watered down the output actions to light blinks for each case (case 1 blinks once case 2 twice etc…)
after each case executes it changes the Boolean lock state (locked = true)
Code
This code will open a deadbolt
with RF remote or buttons and
knows the position of the lock
based on last action
12 RF/Button lock
13 RF/Button unlock
10 button lock
11 button unlock
8 Buzzer
9 Servo
A0 Servo location
4 LED lock
5 LED unlock
const int lockrf = 12; //input to lock rf
const int ulockrf = 13; //input to unlock rf
const int butlock = 10; // button lock
const int butulock = 11; // button unlock
const int ulockled = 4; //led in lock button
const int lockled = 2; //led in ulock button
#include <Servo.h>
boolean lockstate = true;
Servo deadbolt;
deadbolt.attach(9);
pinMode(butlock,INPUT);
pinMode(butulock,INPUT);
pinMode(ulockrf,INPUT);
pinMode(lockrf,INPUT);
pinMode(ulockled,OUTPUT);
pinMode(lockled,OUTPUT);
//variables for code
int lockdeg = 0;
int ulockdeg = 90;
int lock_case = 0;
digitalWrite(ulockled,LOW);
digitalWrite(lockled,LOW);
if (digitalRead(lockrf)==HIGH || digitalRead(butlock)==HIGH && lockstate == true )//locked press lock
lock_case=1;
if (digitalRead(lockrf)==HIGH || digitalRead(butlock)==HIGH && lockstate == false) // ulocked press lock
lock_case=2;
if (digitalRead(ulockrf)==HIGH || digitalRead(butulock)==HIGH && lockstate == true)//locked press ulock
lock_case=3;
if (digitalRead(ulockrf)==HIGH || digitalRead(butulock)==HIGH && lockstate == false) // ulocked press ulock
lock_case=4;
switch(lock_case)
case 1:
digitalWrite(lockled,HIGH);
delay(10);
lockstate=true;
case 2:
lockstate=true;
case 3:
lockstate=false;
case 4:
delay(10);
lockstate=false;
I feel like I've already answered exactly this one today.
When I make code like this:
I always tend to err on the side of too many parenthesis even if they aren't absolutely necessary just in case I got my order of operations messed up.
Do you mean:
if ((digitalRead(lockrf)==HIGH || digitalRead(butlock)==HIGH) && lockstate == true )
or
if (digitalRead(lockrf)==HIGH || (digitalRead(butlock)==HIGH && lockstate == true) )
When posting code, always use code tags.
The box where you post your message has some symbols above it: </> B I U S and so forth. Click on the </> symbol to get the code tags.
