problems with code --> ServoTimeTimer1
I have a problem with some code.
As I already described here http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1195136418/0#0.
I try to build a small robot. Currently I’m butting all bits together. Now I’m struggling with some code I tried.
I want to control two servos with the ServoTimeTimer1 from here http://www.arduino.cc/playground/ComponentLib/Servotimetimer1.
Now my problem (please be patient I’m newbie :-/). Here the code I have:
#include <ServoTimeTimer1.h>
#define servoPin1 9
#define servoPin2 10
#define potPin1 0
#define potPin2 1
ServoTimeTimer1 servo1;
ServoTimeTimer1 servo2;
int myPot1 = 0;
int myPot2 = 0;
int ledPin = 13;                // LED connected to digital pin 13
void setup ()
  servo1.attach(servoPin1);
  servo2.attach(servoPin2);
  pinMode(ledPin, OUTPUT);      // sets the digital pin as output
void ledBlink()
  //BLINK1
  digitalWrite(ledPin, HIGH);   // sets the LED on
  delay(1000);                  // waits for a second
  //BLINK2
  digitalWrite(ledPin, LOW);    // sets the LED off
    for (myPot1=0; myPot1<=180;  myPot++)
      servo1.write((myPot1*2)+500);
      ledBlink();
    for (myPot2=0; myPot2<=180;  myPot2++)
      servo2.write((myPot2*2)+500);
      ledBlink();
    for (myPot1=180; myPot1>=0;  myPot1++)
      ledBlink();
    for (myPot2=180; myPot2>=0;  myPot2++)
      ledBlink();
Here my problem:
 In function 'void loop()':
error: 'myPot' was not declared in this scope
Can you please help? :-?
Greg
the clue to the problem is in the error message: “myPot was not declared…”
in this for loop you are incrementing a variable called myPot when you intend myPot1.
BTW, I think servo2.write() expects a value between 500 and 2500, not an angle. So you may want to do something like:
for (myPot1=500; myPot1 <= 2500; myPot1++)
in fact, many servos expect a range between 1000 and 2000 microseconds so I would start off with that and increase the range after verifying that the servos don’t hit the end stops.
:o
I'm stupid
:frowning:
Thanks for your hint!
Greg
