Problems with code
I'm developing a star tracker project and I cant figure out how to get the stepper motor to move. Can someone please help me write a simple test code to get the motor to work, or maybe the problem is with the connections. I'm currently a total noob in this and help would be appreciated :pray:
While you wait for help, help yourself.
Start here
https://docs.arduino.cc/libraries/tmc2209/
a7
Where did you get the idea for the diagram from ?
I’m sure there’s some code there as well.
Show us what you’ve tried.
For the TMC2209, you will need Hardware Serial TMC2209/examples/UnidirectionalCommunication/StepAndDirection/StepAndDirection.ino at main · janelia-arduino/TMC2209 · GitHub
For other stepper drivers:
// Define pin connections & motor's steps per revolution
const int dirPin = 9;
const int stepPin = 11;
const int stepsPerRevolution = 400;
	// Declare pins as Outputs
	pinMode(stepPin, OUTPUT);
	pinMode(dirPin, OUTPUT);
	// Set motor direction clockwise
	digitalWrite(dirPin, HIGH);
	// Spin motor slowly
	for(int x = 0; x < stepsPerRevolution; x++)
		digitalWrite(stepPin, HIGH);
		delayMicroseconds(2000);
		digitalWrite(stepPin, LOW);
	delay(1000); // Wait a second
	// Set motor direction counterclockwise
	digitalWrite(dirPin, LOW);
	// Spin motor quickly
		delayMicroseconds(1000);
Ive tried this code from this tutorial In-Depth: Control Stepper Motor with A4988 Driver Module & Arduino . And I also changed my driver to an 4988 temporarily so this code is for a4988
do you have the enable and reset wired up correctly? both need to be connected HIGH
oh, i dont have my enable wired anywhere, my reset and sleep are connected together
Enable HIGH is disabling driver...
right thanks
don't understand the blue line between sleep and reset.
would be best to wire Reset HIGH (Vdd) and as @kmin pointed out, Enable LOW (ground)
did you also separately wire Vdd and Vmot? And tie all the gnds together on both boards
Okay, ill try connecting all the grounds together and wiring reset to vdd. Thank you
/SLEEP - logic high allows normal operation
/RESET - STEP inputs are ignored until the /RESET input is set to high
ok. make sure this is HIGH as well
