Hello;
I'm having a problem related to const char* and String types.
When deserializing with the String type in the "Unit" class, everything goes fine. However, if I override the type to const char*, things get lost and become unstable, assigning other values to the variables.
Here's the result as an example.
With string:
4:32:01.859 -> Mensagem chegou no topico: fikerplunk/Test/LockerCriando classe lockers...
14:32:01.904 -> Mensagem chegou no topico: fikerplunk/Test/UnitCriando classe units...
14:32:01.997 -> Quantidade de units
14:32:02.044 -> 13
14:32:02.044 -> Valor Unit:101A
14:32:02.044 -> Valor Unit:102A
14:32:02.044 -> Valor Unit:103A
14:32:02.089 -> Valor Unit:104A
14:32:02.089 -> Valor Unit:105A
14:32:02.135 -> Valor Unit:11A
14:32:02.135 -> Valor Unit:12A
14:32:02.135 -> Valor Unit:201A
14:32:02.182 -> Valor Unit:202A
14:32:02.182 -> Valor Unit:203A
14:32:02.182 -> Valor Unit:204A
14:32:02.227 -> Valor Unit:205A
14:32:02.227 -> Valor Unit:Portaria
14:32:02.272 -> Valor Unit:101A
14:32:02.272 -> Valor Unit:102A
14:32:02.272 -> Valor Unit:103A
14:32:02.319 -> Valor Unit:104A
14:32:02.319 -> Valor Unit:105A
14:32:02.365 -> Valor Unit:11A
14:32:02.365 -> Valor Unit:12A
14:32:02.365 -> Valor Unit:201A
14:32:02.410 -> Valor Unit:202A
14:32:02.410 -> Valor Unit:203A
14:32:02.410 -> Valor Unit:204A
14:32:02.457 -> Valor Unit:205A
14:32:02.457 -> Valor Unit:Portaria
14:32:02.503 -> Valor Unit:101A
14:32:02.503 -> Valor Unit:102A
14:32:02.503 -> Valor Unit:103A
14:32:02.549 -> Valor Unit:104A
14:32:02.549 -> Valor Unit:105A
14:32:02.595 -> Valor Unit:11A
14:32:02.595 -> Valor Unit:12A
14:32:02.595 -> Valor Unit:201A
14:32:02.641 -> Valor Unit:202A
14:32:02.641 -> Valor Unit:203A
14:32:02.687 -> Valor Unit:204A
14:32:02.687 -> Valor Unit:205A
14:32:02.687 -> Valor Unit:Portaria
With const char*:
14:33:29.687 -> Mensagem chegou no topico: fikerplunk/Test/LockerCriando classe lockers...
14:33:29.780 -> Mensagem chegou no topico: fikerplunk/Test/UnitCriando classe units...
14:33:29.827 -> Quantidade de units
14:33:29.874 -> 13
14:33:29.874 -> Valor Unit:101A
14:33:29.874 -> Valor Unit:102A
14:33:29.921 -> Valor Unit:P⸮L⸮
14:33:29.921 -> Valor Unit:⸮
14:33:29.921 -> Valor Unit:⸮⸮xV⸮⸮1A⸮⸮⸮?⸮⸮⸮?t
14:33:29.966 -> Valor Unit:⸮1A⸮⸮⸮?⸮⸮⸮?t
14:33:30.013 -> Valor Unit:⸮⸮?⸮⸮⸮
Here is the code:
#include <PubSubClient.h>
#include "ArduinoJson.h"
#include <WiFi.h>
#include <WiFiClient.h>
class Locker
public:
String id;
boolean active;
String document;
String status;
int sensorPin;
int relayPin;
int number;
String keycode;
String bookingNumber;
String nrOfDays;
String packetNumber;
const char* typeLocker;
class Unit
public:
const char* name;
//String name;
Locker lockers[99];
Unit units[99];
WiFiClient wifiClient;
PubSubClient client(wifiClient);
int totalUnit;
WiFi.begin("userWifi", "passW1f1");
client.setServer("159.782.456.632", 1883);
client.setBufferSize(20000);
client.setCallback(callback);
client.setKeepAlive(90);
client.loop();
verificaMqtt();
for (int i = 0; i < totalUnit; i++) {
Serial.print("Valor Unit:");
Serial.println(units[i].name);
void connectMqtt() {
if (client.connect("userFikerplunk", "userMqttx", "p4ssw0rd")) {
String sub1 = "fikerplunk/Test/Locker";
String sub2 = "fikerplunk/Test/Unit";
if (client.subscribe(sub1.c_str())) {
Serial.println("Se inscreveu no tópico");
Serial.println(sub1);
if (client.subscribe(sub2.c_str())) {
Serial.println("Se inscreveu no tópico UNIT");
Serial.println(sub2);
Serial.print("falha, erro =");
Serial.print(client.state());
void verificaMqtt() {
if (!client.connected() && WiFi.status() == WL_CONNECTED)
Serial.println(F("DESCONECTOU MQTT, CONECTANDO NOVAMENTE"));
connectMqtt();
void callback(char* topic, unsigned char* message, unsigned int length) {
Serial.print("Mensagem chegou no topico: ");
Serial.print(topic);
String messageTemp;
//json = "";
for (int i = 0; i < length; i++) {
messageTemp += (char)message[i];
if ((String)topic == sub1) {
Serial.println("Criando classe lockers...");
criarClasse(messageTemp);
messageTemp = "";
else if ((String)topic == sub2) {
Serial.println("Criando classe units...");
criarClasseUnit(messageTemp);
messageTemp = "";
void criarClasse(String json)
DynamicJsonDocument doc(30000);
deserializeJson(doc, json);
JsonObject root = doc.as<JsonObject>();
int count = -1;
for (JsonPair kv : root)
count++;
lockers[count].id = kv.key().c_str();
lockers[count].document = (const char*)doc[lockers[count].id]["document"];
lockers[count].keycode = (const char*)doc[lockers[count].id]["keycode"];
lockers[count].number = doc[lockers[count].id]["number"];
lockers[count].status = (const char*)doc[lockers[count].id]["status"];
lockers[count].sensorPin = doc[lockers[count].id]["sensorPin"];
lockers[count].relayPin = doc[lockers[count].id]["relayPin"];
lockers[count].nrOfDays = (const char*)doc[lockers[count].id]["nrOfDays"];
lockers[count].bookingNumber = (const char*)doc[lockers[count].id]["bookingNumber"];
lockers[count].active = doc[lockers[count].id]["active"];
lockers[count].packetNumber = (const char*)doc[lockers[count].id]["packetNumber"];
lockers[count].typeLocker = (const char*)doc[lockers[count].id]["typeLocker"];
void criarClasseUnit(String json)
int count = -1;
count++;
units[count].name = kv.key().c_str();
totalUnit = count + 1;
Serial.println("Quantidade de units");
Serial.println(totalUnit);
This is the json I get by mqtt:
{"101A":{},"102A":{},"103A":{},"104A":{},"105A":{},"11A":{},"12A":{},"201A":{},"202A":{},"203A":{},"204A":{},"205A":{},"Portaria":{}}
Could someone tell me why this occurs and how can I fix it to work with const char*?
Thanks!
