Hello,
I want to creat a MCP3201 (ADC 12 bits SPI) library. I wrote thess files but i have compilation errors like MCP3201 class was nt declared.
sketch (just for compilation test) :
#include "MCP3201.h"
//MCP3201 adc(1,2,3,4);
header :
// MCP3201.h
// classe destinee a gerer le CAN 12 bits SPI MCP3201
#if _MCP3201_H_
#define _MCP3201_H_
#include <Arduino.h>
#include <SPI.h>
class MCP3201
private :
int cs;
public :
MCP3201(int cs, int clk, int dout, int spi_clk=SPI_CLOCK_DIV4);
short read();
#endif
definitions :
// MCP3201.cpp
// constructeur
MCP3201::MCP3201(int cs, int clk, int dout, int spi_clk)
this->cs = cs ;
SPI.begin();
SPI.setBitOrder(MSBFIRST);
SPI.setClockDivider(spi_clk);
pinMode(cs, OUTPUT);
digitalWrite(cs, HIGH);
// methode read
short MCP3201::read()
short val;
byte inByte;
digitalWrite(cs, LOW); // activer echange
val = SPI.transfer(0x00); // recuperer octet MSB
val = val << 8; // decaler pour mettre en MSB
inByte = SPI.transfer(0x00); // recuperer octet LSB
val = val | inByte; // assembler MSB et LSB
digitalWrite(cs, HIGH); // desactiver echange
val = val >> 1; // eliminer lsb
return val & 0x3FF; // conserver les 12 bits
Errors :
Arduino : 1.6.3 (Windows 7), Carte : "Arduino Uno"
Les options de compilation ont été modifiées, tout sera recompilé
C:\Users\maison\AppData\Roaming\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino2/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10603 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\maison\AppData\Roaming\Arduino15\packages\arduino\hardware\avr\1.6.2\cores\arduino -IC:\Users\maison\AppData\Roaming\Arduino15\packages\arduino\hardware\avr\1.6.2\variants\standard C:\Users\maison\AppData\Local\Temp\build2929621838537111412.tmp\class_mcp3201.cpp -o C:\Users\maison\AppData\Local\Temp\build2929621838537111412.tmp\class_mcp3201.cpp.o
C:\Users\maison\AppData\Roaming\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino2/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10603 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\maison\AppData\Roaming\Arduino15\packages\arduino\hardware\avr\1.6.2\cores\arduino -IC:\Users\maison\AppData\Roaming\Arduino15\packages\arduino\hardware\avr\1.6.2\variants\standard C:\Users\maison\AppData\Local\Temp\build2929621838537111412.tmp\MCP3201.cpp -o C:\Users\maison\AppData\Local\Temp\build2929621838537111412.tmp\MCP3201.cpp.o
C:\Users\maison\AppData\Local\Temp\build2929621838537111412.tmp\MCP3201.cpp:6:1: error: 'MCP3201' does not name a type
C:\Users\maison\AppData\Local\Temp\build2929621838537111412.tmp\MCP3201.cpp:17:7: error: 'MCP3201' has not been declared
C:\Users\maison\AppData\Local\Temp\build2929621838537111412.tmp\MCP3201.cpp: In function 'short int read()':
C:\Users\maison\AppData\Local\Temp\build2929621838537111412.tmp\MCP3201.cpp:20:5: error: 'byte' was not declared in this scope
byte inByte;
C:\Users\maison\AppData\Local\Temp\build2929621838537111412.tmp\MCP3201.cpp:20:10: error: expected ';' before 'inByte'
byte inByte;
C:\Users\maison\AppData\Local\Temp\build2929621838537111412.tmp\MCP3201.cpp:21:18: error: 'cs' was not declared in this scope
C:\Users\maison\AppData\Local\Temp\build2929621838537111412.tmp\MCP3201.cpp:21:22: error: 'LOW' was not declared in this scope
C:\Users\maison\AppData\Local\Temp\build2929621838537111412.tmp\MCP3201.cpp:21:25: error: 'digitalWrite' was not declared in this scope
C:\Users\maison\AppData\Local\Temp\build2929621838537111412.tmp\MCP3201.cpp:22:11: error: 'SPI' was not declared in this scope
C:\Users\maison\AppData\Local\Temp\build2929621838537111412.tmp\MCP3201.cpp:24:5: error: 'inByte' was not declared in this scope
C:\Users\maison\AppData\Local\Temp\build2929621838537111412.tmp\MCP3201.cpp:26:22: error: 'HIGH' was not declared in this scope
Erreur lors de la compilation.
thanks in advance
