Problems with Data enter, Numbers
Dear forum.
Not new to Arduino But newbe to forum. Not sure were to post this problem.
I am trying to do a information poll with serial monitor,(ask,wait,read).
CODE:
int Temp ;
int x = 0;
Serial.println("Enter a Number___ ");
while (Serial.available()==0) {
//Wait for user response
Temp = Serial.parseInt();
Serial.print("Temp Number is ");
Serial.println (Temp, DEC);
Uploaded code, it compiled and loaded fine.
Opened serial Monitor:
1st Line:
Enter a Number___
Waiting for responses, enter 1 on comand line and enter:
2nd Line:
Temp Number is 1
Enter a Number___
Then after 1/2 second, this line:
Temp Number is 0
Enter a Number__
Monitor screen after 1 input:
Enter a Number___
Temp Number is 1
Enter a Number___
Temp Number is 0
Enter a Number___
I have tried several diferent program examples with same results.
Is this a Computer issue? I am using a Windows 10.
Please HELP Paul H. Hanson.
PS. No hardware on uno R3 Board
You are being bitten by the CR+LF that is also in the input stream. Abandon Serial.parseInt() and read this:
Serial Input Basics and use those examples.
Also, Serial.parseInt() has a timeout if there is no input. Use the idea of blh64.
If you use .parseInt() you should probably clear the input buffer before you prompt for new input:
  while (Serial.available())
    Serial.read();
Thank you johnwasser, That seemed to fix the problem. Why is it allways something simple.
Paul H. Hanson
