Problems with Datalogger code
Working with an UNO and Adafruit datalogger, having a few problems with the code I have put together. I want to write to SD card every minute. Between writes, I want to count the number of pulses from three pulse flow meters. RTC is being used to print the time of each sample. Trying to cut down in delays by using the 60 second pulse sample since the analog reads are only required once a minute. My problems are, the timing is not standard but sporadic. Instead of at set intervals ( which have been shortened for troubleshooting) it prints in bursts, if at all. Second, it's not actually writing to the file. The data will print to the serial window but fails to write to the SD file. As a side note, is anyone aware of conflicts with the Adafruit datalogger and the selected digital pins? I don't have the flow sensors attached and I am still reading pulses so I assume that is the problem. I have attached the code in a separate file.
DataLoggerNew.ino (11.3 KB)
#define pulseReadPin 4          // digital 5
#define pulseReadPin 5          // digital 6
Aren't those the I2C pins? The ones you need for the RTC?
char fn[] = "DD-MM-YY.CSV";
for (int i=0;i<=dataFilename.length();i++) {
    fn[i] = dataFilename.charAt(i);
Since fn[] is only 12 characters wide, you should be checking here that you aren't over 12 characters.
PulseOutput p[3];            //Pulse output objects
You create it with 3 objects...
But then you try to access the 9th, 10th and 11th of those 3 objects.
    p[8].pulse(0,b,time);                //digital input 8
    p[9].pulse(1,b,time);                //etc
    p[10].pulse(2,b,time);
The compiler won't complain since it is technically legal, but who knows what is sitting out there in memory 5 slots past the end of your array. Anytime you have something like this you're going to have unpredictable results. There's no use troubleshooting any further until this is fixed.
And again here:
 for (int i=8; i<=10; i++)              //For all inputs:
        // Serial.print(p[i].rate(time));
         //Serial.print(':');
         //Serial.print(p[i].count);  //Print values
         //if (i!=13) Serial.print(',');
         p[i].count = 0;
And again here:
dataFile.print(p[8].count);
  dataFile.print(", ");
  dataFile.print(p[9].count);
  dataFile.print(p[10].count);
And one more time for good measure:
  Serial.print(p[8].count);
  Serial.print(", ");
  Serial.print(p[9].count);
  Serial.print(", ");
  Serial.print(p[10].count);
So if I am only using 3 pins I should keep those positions to 0-2 of the register instead of picking and choosing?
DHResearch:
It's not a register. It is an array. If you don't know how those work then you should hit up some C++ tutorials before going any farther with this.
Right, sorry. It's my understanding that PulseOutput p[3] creates an array of three positions. But the values that enter those three positions are affected by the change in state of the register. I have changed the points you outline to p[0], p[1], and p[2] but I still get the same issues.
DHResearch:
Nope. The indices to an array are pretty straight forward. There are no registers involved. If you create an array with 3 elements then they are numbered 0, 1, and 2.
Post the new code.
Did you also fix the issue with the I2C pins?
Here is the code. Adjusting the array did fix the writing to file problem (though it doesn't write properly to the window now?). Still getting one pin with a large pulse count despite now sensor being connected. Thanks by the way for your help.
Delta_G:
I see you haven't fixed this. If you're going to try to read a pulse sensor and do I2C on the same pins, I think you should expect some weird results.
I removed those now. Finally understood my mixup with the array/ register confusion after reading more. Those defines were never called, would they still affect the readout?
DHResearch:
No, but they sure serve to confuse anyone reading about which pins you have hooked up where.
Oh, I took your word that you changed to 0, 1, and 2. You did in a few spots, but you used 1, 2, and 3 in others. 0, 1, and 2 are your only legal indices to a 3 element array.
     p[1].pulse(0,a,time);        // Digital input 1
     p[2].pulse(1,a,time);        // Digital input 2
     p[3].pulse(2,a,time);
  dataFile.print(p[1].count);
  dataFile.print(p[2].count);
  dataFile.print(p[3].count);
Worked on it more. Cleaned up the code and put the file naming/saving part into it's own function. Still having trouble getting an accurate pulse read though. I've chosen digital pins 5-7 for the inputs. These aren't use by the shield, but somehow I am not getting the right pulse count.
DataLoggerNew.ino (11.2 KB)
