Problems with ESP32 to define second UART
Hi everyone,
I am having some problems when using the second UART on the ESP32. I define this UART to use pins 14 and 33, but depending on how I define the UART I see some activity in pin 23 that is defined as an input. :o :o :o
If I configure the format: Serial1.begin(9600, SERIAL_8N1, RX_PIN, TX_PIN);
Then it seems that the TX is also present on TEST_PIN (pin 23) (checked with the oscilloscope)
If I omit the format like: Serial1.begin(9600, RX_PIN, TX_PIN);
Then there is no activity on TEST_PIN (pin 23) (checked also with the oscilloscope)
Both statements shoud be the same since SERIAL_8N1 is the default, but somehow they are not.
I do not unsderstand how these two things are related. Am I doing something wrong?. Am I missing something?. Do I have a faulty chip?.
I have not checked for other combinations. It happens that I was using pin 23 as an input for a project and this issue has driven me crazy for a copuple of days until I trace down the origin.
This is the complete code:
#include <HardwareSerial.h>
#define TX_PIN 33
#define RX_PIN 14
#define TEST_PIN 23
while(!Serial);
Serial.println(“Second UART test”);
pinMode(TEST_PIN, INPUT_PULLUP);
// Serial1.begin(9600, RX_PIN, TX_PIN);
uint16_t i = 0;
for(i=0; i<10; i++){
Serial1.println(“esto es una prueba”);
delay(10);
delay(5000);
