I have problems with the Mega and the new Ethernet Shield (both from DFRobot). If I plug on the Shield and try to run the sample code, it seems like the shield establish a connection, but it doesn't.
My Serial Monitor only keeps repeating the following lines:
connecting...
connected
Verbindung hergestellt
request. <ins>Thatâ??s all we know.</ins>
!location.hostname.match(/(^|\.)(google|blogger|orkut|youtube)\.com$/)){var purePath=location.pathname.replace(/\/[^\/]*$/,"");var cookieSet=document.cookie.split(";");for(var cookieNum=0;cookieNum<cookieSet.leng request. <ins>Thatâ??s all we know.</ins>
I tried it with the basic code to connect to google, tried it in my LAN... Nothing works.
Has anyone an idea of what I can try or what I have to do?
Simple client test code that "usually" works. You need to make the assigned arduino ip address compatable with your router lan ip address.
//zoomkat 4-04-12
//simple client test
//for use with IDE 1.0
//open serial monitor and send an e to test
//for use with W5100 based ethernet shields
//note that the below bug fix may be required
// http://code.google.com/p/arduino/issues/detail?id=605
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 102 }; // ip in lan assigned to arduino
//byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
//byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
byte myserver[] = { 208, 104, 2, 86 }; // zoomkat web page server IP address
EthernetClient client;
void setup(){
Ethernet.begin(mac, ip);
//Ethernet.begin(mac, ip, gateway, subnet);
Serial.println("Better client test 4/04/12"); // so I can keep track of what is loaded
Serial.println("Send an e in serial monitor to test"); // what to do to test
void loop(){
// check for serial input
if (Serial.available() > 0) //if something in serial buffer
byte inChar; // sets inChar as a byte
inChar = Serial.read(); //gets byte from buffer
if(inChar == 'e') // checks to see byte is an e
sendGET(); // call sendGET function below when byte is an e
void sendGET() //client function to send/receive GET request data.
if (client.connect(myserver, 80)) { //starts client connection, checks for connection
Serial.println("connected");
client.println("GET /~shb/arduino.txt HTTP/1.0"); //download text
client.println(); //end of get request
else {
Serial.println("connection failed"); //error message if no client connect
while(client.connected() && !client.available()) delay(1); //waits for data
while (client.connected() || client.available()) { //connected or data available
char c = client.read(); //gets byte from ethernet buffer
Serial.print(c); //prints byte to serial monitor
Serial.println("disconnecting.");
Serial.println("==================");
client.stop(); //stop client
