Problems with fast Serial connection to PC
I’m trying to communicate with my arduino from my pc. I’m sending 1,0,0,0 in a loop and the arduino sends the received data back. However, instead of getting 1,0,0,0 back, this is what I get:
1000
1000
1000
1000
1000
1000
1000
0011
0000
0010
0100
1001
0000
0011
0000
As you can see, it works at the beginning, but starts to get weird after a few messages. Instead of sending 3 0’s it sent 5. Why is that?
Here is my code:
C# Application:
class Program
    SerialPort p;
    static void Main(string[] args)
        Program p = new Program();
        p.initialize();
    private void initialize()
        p = new SerialPort("COM3", 115200);
        p.Open();
        byte[] data = { 1, 0, 0, 0 };
        Thread t = new Thread(reading);
        t.Start();
        while(true)
            p.Write(data, 0, data.Count());
        Console.ReadLine();
    private void reading()
        while (true)
            Console.WriteLine(p.ReadLine());
Arduino:
    delay(5000);
    Serial.println("Program started....");
if (Serial.available > 0)
    for (int i = 0;i<4;i++)
        Serial.print(Serial.read());
The next thing i tried is setting a delay in the loop. This works, but the delay needs to be over 300 ms to get a reliable connection. Sadly, 300ms is far too long for my project…
Any Suggestions?
if there is one character in the receive buffer Serial.available > 0 and the you try to read 4 from the buffer => error!
also fails when there are 2 or 3 chars in the buffer.
try this
if (Serial.available >=4)
Is this a realistic test - I have had no trouble communicating at 115,200 baud. I think I even tried 1Mbaud successfully - but I wasn’t trying to send stuff back the instant it was received.
…R
I tried it with >= 4, but there was no difference. (if there is no byte available, it returns -1)
Do you have some working code for me?
The weird thing is, that this works:
  if (Serial.available() >=4)
  delay(300);
            while(true)
                System.Threading.Thread.Sleep(300);
But withouth the delays, it doesn’t…
@yerst,
my proposed code did only fix the Arduino side.
I assume you have a similar problem at the sending side.
Serial communication is NOT, i repeat NOT instantaneous , it takes aeons of time from the processor point of view.
The delay makes it work as it allows the bytes come in.
        while(true)
This will overflow the receive buffer of the Arduino. Chars will be dropped I assume.
There is no handshake implemented in your code - not in SW not in HW - to align internal buffering.
a small reader- RS232 flow control and handshaking - Lammert Bies -
        while (true)
THis part looks ok as readline will wait for \n
Try this
    private void test()
        while (true)
Thanks!
I fixed the problem now, by setting a delay on my pc of 1ms. (no delay on the arduino side)
while(true)
                System.Threading.Thread.Sleep(1);
This works nice, and might be enough for my project.
But still, is there a more efficient way to do this? (Sorry, i haven't had time to read the link you sent me, maybe it's in there, then just write "It's in there".)
Sorry, i haven’t had time to read the link you sent me, maybe it’s in there, then just write “It’s in there”.)
OK. It’s in there.
