#include <Wire.h> //Needed for I2C to GPS
#include "SparkFun_Ublox_Arduino_Library.h" //http://librarymanager/All#SparkFun_Ublox_GPS
SFE_UBLOX_GPS myGPS;
long lastTime = 0; //Simple local timer. Limits amount if I2C traffic to Ublox module.
while (!Serial); //Wait for user to open terminal
Serial.println("SparkFun Ublox Example");
Wire.begin();
if (myGPS.begin() == false) //Connect to the Ublox module using Wire port
Serial.println(F("Ublox GPS not detected at default I2C address. Please check wiring. Freezing."));
while (1);
myGPS.setI2COutput(COM_TYPE_UBX); //Set the I2C port to output UBX only (turn off NMEA noise)
myGPS.saveConfiguration(); //Save the current settings to flash and BBR
//Query module only every second. Doing it more often will just cause I2C traffic.
//The module only responds when a new position is available
if (millis() - lastTime > 1000)
lastTime = millis(); //Update the timer
long latitude = myGPS.getLatitude();
Serial.print(F("Lat: "));
Serial.print(latitude);
long longitude = myGPS.getLongitude();
Serial.print(F(" Long: "));
Serial.print(longitude);
Serial.print(F(" (degrees * 10^-7)"));
long altitude = myGPS.getAltitude();
Serial.print(F(" Alt: "));
Serial.print(altitude);
Serial.print(F(" (mm)"));
byte SIV = myGPS.getSIV();
Serial.print(F(" SIV: "));
Serial.print(SIV);
I’m using the code provided to me by the people that made the sensor which is called SAM-M8Q. However, I keep getting the “Ublox GPS not detected at default I2C address. Please check wiring. Freezing.” message in the serial terminal. Am I wiring it right? If I soldered it would it work? I have attached pictures.
Wire.begin();
while (1);
Serial.print(SIV);
Wire.begin();
while (1);
Serial.print(SIV);
I’m using the code provided to me by the people that made the sensor which is called SAM-M8Q. However, I keep getting the “Ublox GPS not detected at default I2C address. Please check wiring. Freezing.” message in the serial terminal. Am I wiring it right? If I soldered it would it work? I have attached pictures.Pictures
Have you tried running the i2cbusscan sketch to detect all the devices on the i2c (wire) bus? It will detect your sensor if it is properly wired up and tell you the i2c address it has.
