Building a proximity alarm that sets off a speaker with a certain tone when it detects something within ten centimeters. You can also turn it on and off with a controller. All of this works fine. BUT, when the alarm has been tripped, suddenly the hex inputs start showing up with random numbers, therefore breaking the whole code. Removing the code related to the speaker playing suddenly makes it work. Haven't been able to find any similar issues anywhere. Does anyone know what's up with that? Code attached.
int melody[] = {
NOTE_D5, -4, NOTE_E5, -4, NOTE_A4, 4, //1
NOTE_E5, -4, NOTE_FS5, -4, NOTE_A5, 16, NOTE_G5, 16, NOTE_FS5, 8,
NOTE_D5, -4, NOTE_E5, -4, NOTE_A4, 2,
NOTE_A4, 16, NOTE_A4, 16, NOTE_B4, 16, NOTE_D5, 8, NOTE_D5, 16,
int speakerwire = 6;
int thisNote = 0;
int tempo = 114;
int notes = sizeof(melody) / sizeof(melody[0]) / 2;
// this calculates the duration of a whole note in ms
int wholenote = (60000 * 4) / tempo;
int divider = 0, noteDuration = 0;
// Everything above this is just the song, don't worry about it
bool on;
bool off;
bool audiotrigger;
int trigger_pin = 2;
int echo_pin = 3;
int greenlight = 4;
int yellowlight = 5;
int redlight = 9;
const int RECV_PIN = 7;
IRrecv IR(RECV_PIN);
int pulsetime;
int distance;
void setup ( ) {
Serial.begin (9600);
pinMode (trigger_pin, OUTPUT);
pinMode (echo_pin, INPUT);
pinMode (greenlight, OUTPUT);
pinMode (redlight, OUTPUT);
pinMode (yellowlight, OUTPUT);
pinMode (speakerwire, OUTPUT);
IR.enableIRIn();
void loop ( ) {
if (IR.decode()) {
Serial.println(IR.decodedIRData.decodedRawData, HEX);
IR.resume();
if (IR.decodedIRData.decodedRawData == 0xBA45FF00) {
on = true;
off = false;
Serial.println("IR code is 0xBA45FF00");
if (IR.decodedIRData.decodedRawData == 0xB847FF00) {
off = true;
on = false;
Serial.println("IR code is 0xB847FF00");
while (on == true)
digitalWrite (trigger_pin, HIGH);
delayMicroseconds (10);
digitalWrite (trigger_pin, LOW);
pulsetime = pulseIn (echo_pin, HIGH);
distance = (pulsetime * 0.034) / 2;
if (IR.decode()) {
IR.resume();
off = true;
on = false;
if (distance <= 10)
Serial.println (" Door Open ");
Serial.print (" Distance = ");
Serial.println (distance);
digitalWrite(redlight, HIGH);
digitalWrite(yellowlight, LOW);
digitalWrite(greenlight, LOW);
audiotrigger = true;
delay (500);
if (IR.decode()) {
IR.resume();
off = true;
on = false;
Serial.println("IR code is 0xB847FF00 in loop");
else if ((distance > 10) && (distance <= 20))
Serial.println (" Door Closed ");
digitalWrite(redlight, LOW);
digitalWrite(yellowlight, HIGH);
delay (500);
if (IR.decode()) {
IR.resume();
off = true;
on = false;
else if (distance > 20)
digitalWrite(greenlight, HIGH);
delay (500);
if (IR.decode()) {
IR.resume();
off = true;
on = false;
if (audiotrigger == true) {
for (int thisNote = 0; thisNote < notes * 2; thisNote = thisNote + 2) {
// calculates the duration of each note
divider = melody[thisNote + 1];
if (divider > 0) {
// regular note, just proceed
noteDuration = (wholenote) / divider;
} else if (divider < 0) {
// dotted notes are represented with negative durations!!
noteDuration = (wholenote) / abs(divider);
noteDuration *= 1.5; // increases the duration in half for dotted notes
// we only play the note for 90% of the duration, leaving 10% as a pause
tone(speakerwire, melody[thisNote], noteDuration * 0.9);
// Wait for the specief duration before playing the next note.
delay(noteDuration);
// stop the waveform generation before the next note.
noTone(speakerwire);
audiotrigger = false;
} /// end of while
while (off == true) {
pulsetime = pulseIn (echo_pin, LOW);
if (IR.decode()) {
IR.resume();
on = true;
off = false;
} // end while
