Problems with interrupts on nano 33 ble.
A simple code that works fine on the old arduino nano is not working on the nano 33 ble. It seems to be a kind of problem with the interrupt pins.
I'm working with the pololu magnetic encoder attached to the digital 2 and 3 pins.
Anyone could help?
#define ENCESQ 2
#define ENCDIR 3
long PULSOESQ = 0;
long PULSODIR = 0;
void encoderesq()
PULSOESQ++;
Serial.println(PULSOESQ);
void encoderdir()
PULSODIR++;
Serial.println(PULSODIR);
pinMode(ENCESQ, INPUT_PULLUP);
digitalWrite(ENCESQ, HIGH); //turn pullup resistor on
attachInterrupt(digitalPinToInterrupt(ENCESQ), encoderesq, CHANGE);
attachInterrupt(digitalPinToInterrupt(ENCDIR), encoderdir, CHANGE);
I guess mbedOS does not like you to use the Serial.print in the ISRs. Its a bad idea anyways, ISR should be as short as possible, especially with an OS. Try this.
#define ENCESQ 2
#define ENCDIR 3
long PULSOESQ = 0;
long PULSODIR = 0;
void encoderesq()
  PULSOESQ++;
void encoderdir()
  PULSODIR++;
  Serial.begin( 9600 );
  while ( !Serial );
  Serial.println( "Pin Interrupt Demo" );
  pinMode( ENCESQ, INPUT_PULLUP );
  pinMode( ENCDIR, INPUT_PULLUP );
  //digitalWrite(ENCESQ, HIGH); //turn pullup resistor on
  attachInterrupt( digitalPinToInterrupt( ENCESQ ), encoderesq, CHANGE );
  attachInterrupt( digitalPinToInterrupt( ENCDIR ), encoderdir, CHANGE );
  Serial.print( "PULSOESQ: " );
  Serial.println( PULSOESQ );
  Serial.print( "PULSODIR: " );
  Serial.println( PULSODIR );
  delay( 1000 );
Additionally, I do not think you need to do the digitalWrite to enable the pull ups. I just used a button module I have that has a pull up on board. So, you need to test this with your setup.
you are the man!
It works!
Thank you.
