Your code
#include <Wire.h>
#include "Adafruit_LEDBackpack.h"
#include "Adafruit_GFX.h"
#include "IRremote.h"
#include <LiquidCrystal.h>
// Defining bitmasks for custom letters on the segment display
#define BM_A 0b01110111
#define BM_D 0b00111111
#define BM_E 0b01111001
#define BM_G 0b00111101
#define BM_O 0b00111111
#define BM_P 0b01110011
#define BM_S 0b01101101
#define BM_U 0b00111110
#define BM_DASH 0b01000000
#define BM_CLEAR 0b00000000
Adafruit_7segment matrix = Adafruit_7segment();
const int irSensorPin = 2; // IR Sensor
const int fireLedPin = 3; // IR LED
const int triggerPin = 4; // Trigger Switch
const int reloadPin = 6; // Reloading Switch
const int myAmmoLedPin = A0; // Out of Ammo LED
const int speakerPin = 5; // Piezo Speaker
const int hitLedPin = 13; // Hit Indicator
// Game play variables
int myCode = 1; // Unused at the moment
int maxHealth = 3; // Number of times you can get shot before dying
int myHealth = maxHealth;
int maxAmmo = 30; // Amount of ammo returned on a reload
int ammoCount = 30; // Starting ammo
int deadTime = 3000; // Number of ms you stay dead
int deathCount = 0;
// Initial states for state stores
int triggerState = LOW;
int hitState = HIGH;
int reloadState = LOW;
int lastTriggerState = LOW;
int lastHitState = HIGH;
int lastReloadState = LOW;
// Setup the IR sender and receiver routines.
IRsend irsend;
IRrecv irrecv(irSensorPin);
decode_results results; // Stores the IR receiver results
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
// Setup routine, runs once at beginning.
// initialize the button/sensor pins as input:
pinMode(triggerPin, INPUT);
pinMode(irSensorPin, INPUT);
pinMode(reloadPin, INPUT);
// initialize the LED/Speaker as output:
pinMode(fireLedPin, OUTPUT);
pinMode(myAmmoLedPin, OUTPUT);
pinMode(hitLedPin, OUTPUT);
pinMode(speakerPin, OUTPUT);
lcd.begin(16, 2);
// initialize serial communication for debug
// Adafruit I2C 7-Segment Display backpack initialization
matrix.begin(0x70); // pass in the address
matrix.setBrightness(4);
// Write out the initial display
matrix.writeDigitRaw(1, BM_G);
matrix.writeDigitRaw(3, BM_O);
matrix.writeDisplay();
// Start the receiver listening
irrecv.enableIRIn();
// Startup tone generator
for (int i = 6; i > 0; i--) {
digitalWrite(hitLedPin, HIGH);
playTone(900 * i, 50);
digitalWrite(hitLedPin, LOW);
delay(50);
Serial.println("Ready.");
lcd.print("READY");
// Main loop
// Check if there is a message waiting that can be decoded
if (irrecv.decode(&results)) {
Serial.println(results.value, DEC);
// Check if it is a valid hit routine
// This should be the firing IR code of who you are NOT
// Player1 = 3978641416;
// Player2 = 275977667;
// TODO: Need to change this to accept a range so more than two 'teams' can be in play
// Probalby shouldn't be doing this gross decimal parsing too on the binary values.
if (results.value == 3978641416) {
Serial.println("HIT HIT HIT");
lcd.clear();
lcd.print("HIT BY FALLEN ANGEL!");
lcd.setCursor(1, 1);
lcd.print (myHealth);
// TODO: Less lame hit sound
playTone(2500, 200);
// Reduce their health and then check if they should be dead or not
myHealth--;
if (myHealth <= 0) {
Serial.println("DEAD!");
lcd.clear();
lcd.print("DEAD!");
deathCount++;
matrix.blinkRate(1);
matrix.writeDigitRaw(0, BM_D);
matrix.writeDigitRaw(1, BM_E);
matrix.writeDigitRaw(3, BM_A);
matrix.writeDigitRaw(4, BM_D);
playTone(5000, 1000);
delay(deadTime);
matrix.blinkRate(0);
matrix.print(deathCount, DEC);
matrix.writeDigitRaw(0, BM_S);
matrix.writeDigitRaw(1, BM_DASH);
delay(2000);
matrix.writeDigitRaw(0, BM_CLEAR);
matrix.writeDigitRaw(4, BM_CLEAR);
ammoCount = maxAmmo;
Serial.println("Ready again!");
lcd.clear ();
lcd.print("Ready again!");
Serial.print("Health: ");
Serial.println(myHealth);
Serial.println("IR signal received but not recognized");
irrecv.resume(); // Receive the next value
// read the pushbutton input pins
triggerState = digitalRead(triggerPin);
reloadState = digitalRead(reloadPin);
// Check if the state has changed for the reload pin and then perform a reload if it's been pushed
if (reloadState != lastReloadState) {
if (reloadState == HIGH) {
Serial.println("Reloading!");
lcd.clear();
lcd.print("Reloading!");
delay (1000);
lcd.clear();
lcd.print("AMMO=30! FIRE!");
delay (1000);
lcd.clear();
matrix.print(ammoCount, DEC);
playTone(1000, 100);
playTone(500, 100);
// compare the triggerState to its previous state
if (triggerState != lastTriggerState) {
if (ammoCount > 0) {
if (triggerState == HIGH) {
ammoCount--;
Serial.println("Trigger on");
Serial.print("Ammo: ");
Serial.println(ammoCount);
// clear the screen
lcd.clear();
lcd.setCursor(5, 1);
lcd.print (ammoCount);
lcd.print (" = AMMO");
lcd.setCursor(2, 0);
lcd.print ("BLACK HAWK");
// TODO: Less lame firing sound
playTone(600, 50);
playTone(500, 50);
playTone(400, 50);
playTone(300, 50);
// Fire the IR LED (3x to try and make sure it is received and to keep to Sony protocol)
// This should be the firing IR code for who you are
// Player1 = 0x00B
// Player2 = 0xa90
irsend.sendSony(0x00B, fireLedPin);
Serial.println("Trigger off");
// Out of ammo so flash the display accordingly and play a error noise if they try and fire
matrix.writeDigitNum(0, 0);
matrix.writeDigitNum(1, 0);
matrix.writeDigitNum(3, 0);
matrix.writeDigitNum(4, 0);
matrix.blinkRate(2);
//digitalWrite(fireLedPin, LOW);
digitalWrite(myAmmoLedPin, HIGH);
Serial.println("Out of myAmmo!");
lcd.print("Out of Ammo!");
lcd.clear();
playTone(5000, 100);
//delay(40);
lastTriggerState = triggerState;
// Play a sound on the piezo
void playTone(int tone, int duration) {
for (long i = 0; i < duration * 1000L; i += tone * 2) {
digitalWrite(speakerPin, HIGH);
delayMicroseconds(tone);
digitalWrite(speakerPin, LOW);
