Problems with Joystick and Adafruit Motor Shield
I'm kind of new to arduino and c++ so forgive me if the coding is messy.
I have connected a analog joystick and adafruit motor shield to my arduino. The joystick should control the dc motors direction and speed. I have created a formula to translate the value of VRx on a scale of 1024 to 0, to a scale of 255 to -255. A if command then makes the negative value positive. The formula works well on a calculator but is a bit weird on the arduino. In the serial monitor it reads the default value (0) of motorSpeed as 47 and the max as -30 and min as 1. Also for some reason the motor will only move forward when i move the joystick but not backwards. Also for some reason when the joystick is not being touched the motor moves very slowly backwards. I fairly sure that this is not a motor problem as i have tried switching the polarities. Please help as i have no idea what is going on.
Here's my code:
#include <Wire.h>
#include <Adafruit_MotorShield.h>
#include "utility/Adafruit_MS_PWMServoDriver.h"
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
Adafruit_DCMotor *myMotor = AFMS.getMotor(1);
int VRx = 0;     // Y direction
int VRy = 0;     // X direction
int motorSpeed = 0;
  AFMS.begin();
myMotor->setSpeed(0);
VRx = analogRead(0);
VRy = analogRead(1);
motorSpeed = 255 * (VRx - 512) / 512;   // Makes the VRx value on a scale from 1024 to 0 translate to a scale from 255 to -255. 512 being 0, 1024 being 255 and -255 being 0.
if (motorSpeed < 0) {
motorSpeed * -1;     // Makes motorSpeed value positive
Serial.println(motorSpeed);
if (VRx > 520) {         // Not exactly 512 to give a bit of "Wiggle" room.
  myMotor->setSpeed(motorSpeed);
  myMotor->run(FORWARD);
if (VRx < 515){
      myMotor->run(BACKWARD);
Very strange names or comments.
You will encounter overflows, all operands are 16 bit integers.
motorSpeed = 255 * (VRx - 512L) / 512;
The above forces the compiler to use 32 bits for the expression.
Or you could achieve the same result by declaring VRx as a long and leaving the calculation as it is in your code
Personally I think I would use
motorSpeed = map(VRx, 0, 1023, -255, 255);
as it is more obvious what is going on (at least to me)
